Old 02-11-2006, 09:32 PM
escort_jay102 escort_jay102 is offline
Very Very Confused!!! HELP!
I have a 93 1.9L LX sedan with 78K on it. My 2nd to last mileage was 28mpg, this last time, it was 26.5 and it is slowly decreasing. I dont know why it is doing it, but I am kinda getting sick of fixing my escort. I recently changed my plugs/wires, cleaned my K&N airfilter, and I am using some NEW product called Bio-Performance that I was putting in after I filled up, but then realized I was putting it in wrong and now I am putting it in before I fill up. Then my mileage started to decrease. I am so confused, I am getting fed up with this escort. I turn around and something else needs to be done with it. Does anyone think I need to have the Fuel Injection System flushed or something. I really dont use heat all too much...maybe a 1 out of 4 on the dial. The tires are all balanced correctly and properly inflated.. I noticed there is a slight pull to the right, but that would not do anything to the mileage would it? I am lost.. please help me..Oh, and that Bio-Performance stuff is guaranteed to not screw up an engine, so it is completely safe to use.
1998 Chevy Cavalier
2.2/ K&N/ Ractive muffler
1994 Chevy s10
thrush welded muffler
Old 02-11-2006, 11:00 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: Very Very Confused!!! HELP!
sounds as though maybe a caliper is sticking which in turn may be adding drag think thats possible?
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 02-12-2006, 12:57 AM
KimMG KimMG is offline
AF - Advisor
What's your fuel mileage without the additive?
Old 02-12-2006, 04:06 PM
mileage without the additive was 25mpg..so i dont think that is a good gas mileage...at all..
i also hope that the caliper is sticking so then it would be an easier fix. thanks..I will check it out tomorrow..
1998 Chevy Cavalier
1994 Chevy s10
Old 02-12-2006, 06:28 PM
Escorts4ever Escorts4ever is offline
A couple of questions... Do you live in a colder climate and are you letting your car warm up in the morning? My 95's get about 6 to 7 mph less in the winter time than in the summer. If you think that you have a hanging brake, don't forget to check the rear too. If you have one rear brake hanging, for example a hung brake e-brake cable, it too can give you a pull.
Old 02-12-2006, 08:43 PM
chevyn0va1's Avatar
Good point i have heard that also check the e brake cable.
Old 02-13-2006, 07:39 PM
yes i live in a colder area..michigan. and no i dont let me car warm up.. I know I really should but I dont. I will check out those brake ideas..thanks guys, i just want my lil scort fixed because it runs real good
1998 Chevy Cavalier
1994 Chevy s10
Old 02-14-2006, 07:39 PM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
Your car is 13 years old, do you exspect it to last forever with out service? When was the last time you replaced the O2 sensor? That additive might be safe for the "engine", but it does'nt take much to screw up an old O2 Sensor, and there directly related to gas milage.
I make slow Escorts less-slow.
My cardomain
Old 02-14-2006, 09:01 PM
chevyn0va1's Avatar
then another debate (at least in the 99) there is 2 sensor one before and one after the cat.
Old 02-15-2006, 12:16 AM
Davescort97 Davescort97 is offline
Escort guy
jeffescortlx I think is onto your problem. The 02 sensor becomes contaminated from fuel additives or any kind of silicone spray cleaner. I don't think the poor fuel mileage is due to emissions problems. You'd get a code if that was the case. Replace the 02 sensor. There is just one on the inilet pipe of the cat.
Old 02-19-2006, 12:50 PM
thumpa thumpa is offline
my 1994 escort iz looseing power and i dont know why could u help me and when i put my foot on my front breaks the car gose from side to side and cuts out if u could help me thanks
Old 02-20-2006, 11:15 AM
On Obd2 (96 and newer) the first O2 (closest to the manifold) is the important one that effects perfromance and gas milage. The 2nd O2 is just there to trip the cel if there's a problem with the cat.
My cardomain
Old 02-28-2006, 08:38 PM
thanks for the important info guys.. I never thought about the O2 sensor at all.. Is it hard to change? I mean can I do it myself? I hope so,... and now I am getting worse mileage. my worst is 21.5 and I think I am beating that with this tank. If I change the O2 sensor, can I still put the Additive in there again or cant I??
1998 Chevy Cavalier
1994 Chevy s10
Old 02-28-2006, 09:18 PM
chevyn0va1's Avatar
Very easy to do you'll jjust need a special wrench its a deep socket that has a grove in its side (for the wire). All availlable at autozone.
Old 02-28-2006, 11:09 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
that additive, despite what it says on the bottle may cause you problems... i doubt it is the gas milage problem though. i have read articles on how over time, if used consistently octane booster can foul spark plugs, they become covered in a red "dust" and the spark has a hard time finding a ground... this can lead to the spark eventually grounding on the ignition coil... which means you have to replace it and spend some big $$. thats a short explantation.
with the pulling, you said the tires are balanced and inflated properly, however you didnt say it was alinged properly...
this one is just a wild guess, cause if this goes real bad the car wont run at all. could the map sensor be messed up? this went bad on my escort with the same engine. but mine just got fried and the car died, but i suppose if it was working but working improperly it could screw up the timing and fuel mixture.
