Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 02-11-2006, 09:12 PM
pada's Avatar
pada pada is offline
Question 2000 Jetta 2.0 ..... T/Belt?
Hello everyone,
My son has a 2000 Jetta with the 2.0 non-Turbo engine. VW recommends the T/Belt be changed at 90k, but the dealer is quoting over $500 to do it.
What would be a realistic expectation to pay at a quality independent shop?
Also, can anyone tell me for a certainty if this is an "Interference" engine or not?
Finally, has anyone attempted a DIY T/Belt replacement on this motor? Tell me your stories ...
Thanks!
Paul (pada)
San Diego
Old 02-12-2006, 09:19 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: 2000 Jetta 2.0 ..... T/Belt?
2.0 is very simple to change t-belt on. hardest part is removing the engine mount.
would really reccomend replacement of the water pump as they are a very common problem and its almost sure the new belt and tensioner will cause the w-pump to fail and you will be looking at a 2500.00 cylinder head replacement.
yes all vw engines are interfearance accept the 98 and older 2.0
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 02-12-2006, 10:03 PM
pada's Avatar
Cool ... Thanx veedubmechanic!
I've done a couple of other T/Belts in the past and the infamous Head Bolt Campaign on my old 325i ... So a non-pro like myself who's halfway handy with a set of wrenches should be OK to do it with a decent manual in hand ... ? No special tools?
Paul (pada)
Old 02-14-2006, 05:19 PM
VDUBMAN
no special tools on 2.0
just make sure the timing marks are aligned up and you replace the w-pump and tensioner and you should be ok.
Old 02-15-2006, 07:28 AM
pada's Avatar
Thumbs up Re: 2000 Jetta 2.0 ..... T/Belt?
Great advice, thank you! ... I'll let you know how it turns out
