Old 02-11-2006, 08:18 PM
2002sunfiregirl 2002sunfiregirl is offline
Question sunfire clunk
I just bought a 2002 sunfire SES and occasionally I hear a "clunking" noise from under the hood, close to the base of the windshield. What could this be?
As well, there is a light which comes on the dash when the parking break is "ON" which reads "trac off", what does that mean?
Old 02-11-2006, 08:23 PM
JeRkY2 JeRkY2 is offline
Re: sunfire clunk
When do you hear the clunking noise? Turning? Driving straight? It could be you strut bearings. They are fairly common on those cars.
The "Trac off" light means that the traction control is off beacause the parking brake is set.
Old 02-11-2006, 08:30 PM
Re: sunfire clunk
Thank you for the explanation of trac.
The clunking is when i'm turning as well as at times, just driving straight, it sounds like it is up high , just under the hood, not so much where the struts would be.
Old 02-11-2006, 08:39 PM
Re: sunfire clunk
Strut bearings are fairly common on Sunfires and Cavaliers. you may want to have them checked anyway. The strut bearings are on the top of the strut where it mounts to the chassis, which is closer to the hood.
Since you are hearing this noise at times other than turning it could also be worn stabilizer links. New link kits are not normally too expensive if that is what the problem is.
Old 02-11-2006, 10:01 PM
Red face Re: sunfire clunk
You have been extremely helpful.
Thank you for your responses.
Old 02-12-2006, 10:30 AM
muff34 muff34 is offline
Re: sunfire clunk
It could also be the intermediate steering shaft as this is common on these cars also . I had mine replaced .2000 Sunfire. I would notice it while moving slowly ,like backing out of the driveway or moving around in a parking lot. just my
Life Is A Highway ,Enjoy The Ride
Old 02-14-2006, 06:35 PM
03CavyMan 03CavyMan is offline
Send a message via AIM to 03CavyMan Send a message via MSN to 03CavyMan
Re: sunfire clunk
That sounds like a strut bearings to me. If it squeaks a bit going over bumps then the mount is likely dry and wearing out, spray some Cheetah grease in for a temporary fix. If the car has a hard time coming back to steering in a straight position after making a turn, then your strut bearings need to be replaced.
If it's an intermediate shaft, you'll be able to feel it when making a slight turn at low speeds, and you'll feel it in the steering wheel when it clunks.
2000 Chevrolet Silverado Regular Cab Short Box
4.3L Vortec - 5 speed
Ion Alloy 16x8" chrome wheels
Magnaflow Catback Exhaust
K&N Intake, Throttle Body Spacer
GM Automotive Technician
Previously - 2003 Chevrolet Cavalier
Old 04-23-2009, 10:56 PM
dwyczalek dwyczalek is offline
Re: sunfire clunk
I also have a 95 Sunfire that clunks on turns and bumps (on right Side) I just replaced the tie rod end an notice the top of the strut moves around a lot it seems like the strut itself is ok my question is, is it going to be the strut mount or the strut bearing that is bad.
Also can you just change the bearing by itself or do you have also replace strut mount once you take it apart.
I would like to get by without changing the strut if possible.
It doesn't squeak either.
What do you recommend?
Doug
Old 04-24-2009, 05:31 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: sunfire clunk
Oh, come on! Did you search for "old posts"?
http://www.automotiveforums.com/vbul...uidelines.html (start a new thread)
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
