Well here goes this is my first post here.All my marker lights back-up lights and fog lights work 100% but as soon as I turn my headlights on or they turn themselves on the relay in the dash mounted headlamp switch kicks off. It seems to try and recycle every 10-15 seconds or so but then clicks off immediatly.I removed all the bulbs but that makes no difference. I've visualy inspected as much of the wires as I can see they all look perfect. This is driving me crazy I can only drive sun-up to sun-down. Are there any tricks or logical steps I should follow try to trace a short(I'm asuming that's the problem)
Thanks ls1geezer |
Re: 98 How to find a short?
Hello. One thing you can start off with is changing the switch or the relay
You might want to check the circuit breaker(controls the 'recycle every 10-15 seconds' you mentioned). In your car, I dont know where it is in your car. Fuse block or in the headlight switch itself? I dont know.
Might also want to check your headlight swith and wires connecting to it if you havent already done so. |
