Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 02-11-2006, 09:08 PM
sspowersports sspowersports is offline
89 4wd bronco II auto trans problem
i put a new flywheel on it and now it will not shift, i noticed a chip in the outer shaft end while i was installing the tork converter. could it be the problem.i checked the modulator and tv cable and adjusted everything i can think of and it still will not shift. the chip is only about a 1/4 inch around and is only back to the small groove in the shaft.any help would be great.
Old 02-12-2006, 10:59 AM
Truck Truck is offline
Re: 89 4wd bronco II auto trans problem
Not to be dumb, but did you fill it properly? The AT won't shift if the fluid level is incorrect. I'm not so sure about the crack.
Old 02-13-2006, 04:03 PM
yes we checked that first, but it is good question.
thanks
