Old 02-11-2006, 08:30 PM
blazer_guy86's Avatar
blazer_guy86 blazer_guy86 is offline
Replacing the cat.
Got a 98 (which i hear are famous for bad cats) that needs a new catalytic converter. What i'm wanting to do is just simply cut the old one off and somehow bolt on a new one considering i really don't have access to a welder. My question is, can i do this and how hard would it be? I think i needa 2.5" cat. Is this correct?
I found this cat on ebay. Does anyone think this one will work? Thanx.
http://cgi.ebay.com/ebaymotors/Carso...QQcmdZViewItem
Old 02-11-2006, 09:12 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: Replacing the cat.
That should work.or http://cgi.ebay.com/ebaymotors/Easte...QQcmdZViewItem
You just might have to add pipe if there not the same lengths.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 03-21-2006, 01:17 AM
Jon Teeter Jon Teeter is offline
You can buy an aftermarket cat from autozone that you can bolt right on with muffler clamps
Old 03-21-2006, 07:37 AM
old_master's Avatar
Advisor/Moderator
Either one will work just fine however, they should be welded into the system for best results. Usually a shop will weld it in for you at a nominal cost.
Old 03-21-2006, 05:39 PM
wafrederick wafrederick is offline
Banned
Weld the cat. on,no clamps.Stay away from the one from AutoZone(really called AutoJunk).The fastest way to cut the old cat is a recipicating saw with a 6'' 18tpi blade.Do not throw the old one away and there is a reason why.The old one is worth some money,$50.00-$60.00 for the old cat.There are guys out there buying them from auto repair shops,auto salvage yards just for the metals inside.
