| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Does anyone have a how to on how to paint your interior a certain color? Is there complete instruction someone can show me, like priming and what sort of products to use and how to use it.
How-To paint your interior parts
Painting various parts of your car is a simple way to add style without spending a lot of money. You can paint virtually anything in your car that you want. You can use just about any kind of spray paint, but try to find the kind made by SEM. It's the stuff used by most professional upholstery shops and is the best stuff you can buy for this type of application. On any non-metal surfaces do NOT use engine paint or other metal paints. It will eat up your plastic pieces, and also doesn't stick to them as well(I learned this one from experience). To start, find some paint in the color of your choice. I would recommend using something not too glossy because it repels dust better, and will match the factory look better. Clean off all your pieces with hot soapy water and rinse them. If there are any large scratches, fill them with body filler or primer or something before you paint them. Once everything looks okay, set your pieces out and apply thin, even coats of paint about 10 minutes apart. Continue doing this until you have the surface sufficiently coated with paint(3-4 coats should do fine). After you are finished, allow the pieces 24 hours to dry before putting them back on your car. You can put them back on sooner, but 24 hours is a good idea so the paint will be fully cured. Once the paint has dried completely, buff the pieces out with a soft cloth to remove any excess material. Put the pieces into your car, and apply something like Finish 2001 to the pieces. This makes them a little more glossy, and matches the rest of your car better. Do NOT use Armor All because it will eat your paint. For the plastic pieces: (1) Remove pieces that you desire to paint; (2) Clean throughly; (3) Apply 2 coats of primer - waiting 5 minutes between par instructions; (4) Spray a - - t h i n - - coat of spray paint - yes, it will not look like it touched it but very barely, but have patience. BTW: definition of thin - no closer than 12 inches from the object. If you get to close, the paint will become thick and "ball up" on you; (5) Allow to dry for 7+ minutes depending on piece size - use own judgement; (6) Repeat steps 4 & 5 as many times as you want - personally, I probably did over 10 coats to ensure that I got every nook&cranny; (7) IMPORTANT STEP: let sit for 12-24 hours (this is probably the most difficult part because I know you want to rush and put the piece back in your ride and check it out) and after it is completely dry - go over it with a cloth; (7a) FOR A GLOSSY LOOK: add a coat or two of clear coat to your piece; (8) Put it back where it belongs.
2000 BMW 323IT 1954 Ford F100 With every post my penis grows smaller Yakima Valley Truck Club Yakima Washington |
