Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 02-11-2006, 04:06 PM
zroc86 zroc86 is offline
Question Hey guys I am new and need a lil help fast.
Alright got the girlfriends 95 GTC Vert 3.0 V6 here. Ok long story short we got the car from her dad and I was goin to take it to check things over. it needed an alternator he said which it did so when I replaced it the fuel pump ended up diein so we replaced it got it goin and now we have a check engine light and very low voltage. I grabbed the tester from work, I am a technician at a Nissan dealer, and it said that it is not recieving charging voltage. The battery was also replaced during all of this. So I have a new battery and a new alternator but not getting any alt. output to battery. Any suggestions? Any diagrams for the charging system? Is there a way I can get the codes to flash out like with my GMs? Somewhere I was told the Voltage Regulator is in the ECM. It may have been in what I read on ALLData. I know nothing about Chryslers. None of the auto stores have a Haynes or Chiltons manual for the car and I need to get this thing goin soon so I dont have her grandpa down my neck about her borowing his Jeep. Thanks.
Old 02-11-2006, 05:42 PM
EnergyForce EnergyForce is offline
Re: Hey guys I am new and need a lil help fast.
on my 93 Lebaron I can pull engine codes using the on-off-on-off-on sequence by turining the key to the on and off positions (but not starting the car or making it turn) 5 times and the check engine light will blink out codes for me. Dont know if that will work for you.
Old 03-13-2006, 02:05 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
that will work for ya, and no the voltage regulator is not in the pcm, it was on the older 4 cyl versions. There is a fusible link behind the battery that the alt goes thru, it may be blown becaus of the ne alt.
Old 03-20-2008, 08:25 PM
racoondp racoondp is offline
well here goes guys**...you said that there was ..no output from alt. to the battery...correct? if so did you test the replacement alt for faulty diode? you may have gotten a bum reman. it happens more often than not...remember what my old boss told me...A brand new lightbulb can be bad! He owned the Auto Electric repair shop I wrote service for aprox.24yrs ago...**now you know...why I say this...everything changes in manufacturing...diode check used to be first line defence/diagnosis in the charging system.
Old 03-27-2008, 12:28 AM
madmanmapper's Avatar
madmanmapper madmanmapper is offline
You know what, when I put a good battery in my friend's Dynasty and drove it home, I thought it somehow killed the battery but was still charging the system. Turns out that since I had to jimmy the battery in there, I pulled out the plug on the positive wire. Yep, there is a wire that goes from the positive battery terminal to the under-hood fusebox, and it has a plug in the middle, it was unplugged!
So yeah, check the alternator and all of the wires.
And I thought even the 3.0L had externally regulated alternators...my 3.0L's alternator has a badge on it that clearly says "EXTERNALLY REGULATED"...
Old 04-29-2008, 02:58 PM
doughert0 doughert0 is offline
If you're gonna keep it, swing for $90 for a ''95 Service Manual. I expect you can order through your dealer, or on line.
