Old 02-11-2006, 02:54 PM
iponnet iponnet is offline
compression test results!
alright I did a compression test on my 91civic dx to find out why I am loosing so much oil and here are the results
(cyl #1: 163)(cyl #2: 155)(cyl #3: 157)(cyl#4: 152), now I look up the specs and I think I should have a compression of 175-185(?) so this means on all cylinders there is some sort of a problem, but this doesnt seem bad enough to cause the loss of a qrt of oil per 400-500miles, does it? I must add I did this test after I did a valve lash adjustment so I dont know how that could effect this! let me know what you guys think...
thanks in advance
Old 02-11-2006, 03:07 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
Re: compression test results!
could be a few of things, piston rings are not sealing properly or valve seats.
try this, put a spoonful of oil in the cylinder and re-test it. if the result is higher your piston rings are not sealing properly, if result is similar, the valve seats are to blame.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 02-11-2006, 06:58 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
time to do the leakdown.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 02-13-2006, 05:51 PM
kris's Avatar
kris kris is offline
Off playing with fire.
135 should be about the minimum. Also, each cylinder is pretty close to the 10% margin. You dont have a perfect motor, or a bad motor. Just a little tired.
Old 02-13-2006, 06:34 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
I agree with Kris. I think the compression should be somewhere between 135-185. With yours still being where its at, I would just see it as a tired motor, nothing too serious. If it were lower than 135, yea, check the rings, then the valve seats, but I wouldn't worry about it yet.
Tony
91 Civic Sedan DX - Stock 287k Miles
