Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 02-11-2006, 02:39 PM
|WYG|SS |WYG|SS is offline
oil light
i have gotten the codes red for the check engine light and i had to replace the O2 sensor and took it on highway and once i got off and at a light again the oil light came on, it only comes on when i turn steering wheel. what could be causing this? A bad alternator?
Old 02-11-2006, 03:36 PM
muff34 muff34 is offline
Re: oil light
Does it come on when you are moving and turning a corner or just when you are stopped and maybe turning the wheel? If by chance it only does it when you are stopped try this. Leave it in PARK rev it up a bit turn the wheel .does light go out ? If light goes out then and it only does it at idle ,then maybe the oil pressure is getting low as the engine has to work abit harder to turn the wheels thus dropping the Rpm and therefore dropping the oil pressure.just my
Life Is A Highway ,Enjoy The Ride
Old 02-11-2006, 08:58 PM
Re: oil light
i pulled into walmart parking lot and turned the wheel and the light just flickerd but didnt go straight on. welll i took a bolt i had laying around and put it over the idle screw and the oil light never came on (the bolt was about a little bigger than 1/8 inch thick and the screw was out about 1/8 so it made idle up faster.
Old 02-12-2006, 10:09 AM
Re: oil light
well if it just " flickered" I`d suspect a bad connection possibly at the sensor or the engine stumbled and was about to quit.
Old 02-12-2006, 01:52 PM
Re: oil light
well as i go under the car everytime i see lots of oil build up that i willl tru and get rid of with engine degreaser in the summer casue it is just thick. should i put car up on ramps when i do this cause this is probably one of the problems im having bad sensors?
