Old 02-11-2006, 02:10 PM
nics0117 nics0117 is offline
95 Ford Escort Dashboard Lights
I am new to this and just bought this car. The dashboad (speedometer, fuel guage, and takometer) don't work. I went and bought a new intrumental cluster and put in new bulbs, still does not work. Anyone have any thoughts on this? Thank You in advance.
Old 02-12-2006, 01:34 AM
KimMG KimMG is offline
AF - Advisor
Re: 95 Ford Escort Dashboard Lights
Do the tail lights work? Are you getting power to the bulb sockets? Did you test the headlight switch?
Old 02-12-2006, 08:58 AM
All the light work it is just the five lights that are suppose to light up the speedodmeter and tackodmeter in the dashboard, the blinkers work and all other it is just the five middle lights. The head and tail lights work.
Old 02-12-2006, 06:30 PM
Escorts4ever Escorts4ever is offline
Down under the dash on the drivers side is a rehostat that turns the lights up and down and even off. Is the rehostat turned down??
Old 02-12-2006, 07:20 PM
Question Re: 95 Ford Escort Dashboard Lights
If the rehostat is the same as the dimmer switch then I have found that the dimmer switch is bad and have ordered a new one. The most likely if the fix; right?
Old 02-12-2006, 09:07 PM
dougand3 dougand3 is offline
Yes, rheostat = dimmer switch. Never pulled an Escort one but have others. On some, there is a metal contact that slides over a spring. The spring carries the current. Where the metal contact touches the spring determines how much current goes to light bulbs - longer travel thru spring = dimmer light, shorter travel thru spring = brighter light.
You may be able to clean the rheostat - sandpaper the contacts, dielectric grease on the spring for smooth operation.
Or you can bypass the rheostat - find the in and out wire leads and connect them. It will be at the brightest dash light setting and you can't dim it. Frankly, I've never had an instance where I wanted to dim the dash lights.
83 MB 300SD - 305k miles
93 Escort 1.9L LX Wagon - 220k miles
95 Isuzu 2.3L P'up - 230k miles
Old 02-15-2006, 03:52 PM
mustang302 mustang302 is offline
Does the dimmer control the radio and climate control brightness when you turn on the headlights? If not, I'd say it's the culprit.
