Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-11-2006, 01:52 PM
kruzoo kruzoo is offline
Rodeo 2001 v6 - change plugs?
I've done my share of getting grease on my hands but I'm stupid with this one. I want to change the spark plugs on my 2001 Rodeo v6 but don't have a clue how to get the cover off the installed plugs? I removed the two screws but there is a great deal of resistance when I try to pul the cover off. It seems to be a rubber housing? Help.
Old 02-11-2006, 02:28 PM
rodeo02 rodeo02 is offline
Re: Rodeo 2001 v6 - change plugs?
Yes, it's a whole bunch of fun! I've attacked them with two pairs of needle nosed pliers. Get one on each side of that top grommet, twist, yank and pull . The whole black plastic/rubber tube will eventually pull out of the plug tower. They stick to the sparkplugs from all the hot/cold cycles. Put a dab of silicone greas on the plug tops so the tubes will pull right out next time.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 02-11-2006, 02:39 PM
amigo-2k amigo-2k is offline
Isuzu Guy
http://isuzufaq.ibctech.ca/#faq15
o remove the coil over the plug, remove the two screws, then unplug the connector (two wires going in) then twist twist twist the coil (wrap fingers under the coil), and then twist and pull up. If you only tug up it may not come off the plug. The key to getting to the drivers side firewall plug is to use 2 short extensions, a U-joint, and the long extension. Then by feeding the short extensions into the plug hole one at a time followed by the u-joint and the long extension. -OR- If the have the all three drivers side coils off you can remove the rear drivers side plug using your socket and 2 3" extensions (no u-joints). Also, if you remove all three coil packs you can get to the rear plug with 2 three inch extension and NO u-joint. The easy way to get the plug back in the hole is to place a piece of rubber tube (or a clear flexible tube) onto the end of the plug and then put the assembly into the hole and gently screw it in to assure that you are not cross threading the plugs. Make sure you place some di-electrical grease on the top of the plug and some anti-seize on the treads.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-11-2006, 02:41 PM
Smile Re: Rodeo 2001 v6 - change plugs?
Thanks, I'll give it a yank! I went to Hutch Tech in Buffalo.
Old 02-12-2006, 06:01 AM
Originally Posted by kruzoo
..I went to Hutch Tech in Buffalo.
No kiddin'? I've been a WNY'er all my life (all 35yrs ) Mostly the southtowns. You've come to the right place for isuzu help!
G/luck
Joel
Old 02-12-2006, 04:14 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
Cool, another Buffalonian. I went to ST Joe's (graduated in 94). You still in Buffalo? I live in North Buffalo (by the zoo).
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 02-13-2006, 02:25 PM
kdsrodeo kdsrodeo is offline
Lake Shore Central here graduated in 85, grew up downtown though. Been in FLorida since 1993 (AIr Force) How'd you guys do in the lastest Blizzard?
Old 02-13-2006, 03:02 PM
directory's Avatar
directory directory is offline
Originally Posted by rodeo02
You've come to the right place for isuzu help!l
you aren't kidding!
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 02-13-2006, 03:12 PM
marcre's Avatar
We saw very little snow in the city. I was disappointed because I wanted to take my Rodeo out for some fun four wheeling. There is a lake effect snow advisory right now, but it's nothing so far. Very snow-free winter this year.
My Rodeo
Old 02-13-2006, 04:05 PM
directory's Avatar
i had 7 inches....not that i'm rubbing it in or anything. it was even on a saturday morning..hehe...still not rubbing it in.....
of course, i found out i either need a winch or bigger tires..but we won't talk about that...
SKYWARN
we be clubbin'
--B
