Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-11-2006, 01:46 PM
xskiesgoblackx xskiesgoblackx is offline
valve cover gasket
i took off my valve cover to change my timing belt on my b16(by the way i cant get the tensioner bolt loose-it stripped, not on the inside..just the head of it stipped-any suggestions there?) and when i get the new valve cover gasket do i have to put like grease on it or anything or does it just sit there dry.. and does anyone know the torque settings for the bolts on the valve cover?
Old 02-11-2006, 02:35 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: valve cover gasket
7.2 ft-lbs on the valve cover bolts. though, hand tight is good enough. a torque wrench imo is overkill and not necessary. do what you wish. you should put some permatex grey on the cam and dizzy ends of the gasket.
as for your srtipped bolt. get this from sears.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 02-11-2006, 04:14 PM
thanks and does anyone know if the tensioner bolt is threaded the opposite way- since the wheel spins to the left instead of the right? cuz i have no idea why it would strip
Old 02-11-2006, 04:56 PM
AF - Advisor
lefty loosy, righty tighty.
Old 02-11-2006, 07:49 PM
ive been usin that since i was like three- but considering the tensioner spins to the left would they thread it the opposite way or nah?
Old 02-12-2006, 10:41 AM
AF - Advisor
the tensioner is not tightened down tight enough to where you would strip the head.
follow:
lefty loosy, righty tighty on all bolts on your car
and you will be fine.
