Old 02-11-2006, 12:01 PM
reedster reedster is offline
transmission swap
Hi All,
I have two 1989 s-10's, 4x4
one has 2.8 liter with 5 speed manual,single cab, long box
other 4.3 liter with automatic,cab and half, short box
would like to put manual transmission behind the 4.3.
Was told by retired Mr. Goodwrench it is not possible.
Your thoughts are welcome!
Old 02-11-2006, 10:55 PM
OverBoardProject OverBoardProject is offline
Banned
Re: transmission swap
Welcome to Automotive Forums reedster
Not possible, the bell houses aren't the same any you can't remove the bell housing on the 5 speed.
I looked and never found any adaptor plates for the 2.8L pattern either.
Old 02-12-2006, 04:57 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
not possible, obp hit the nail on the head, you need a small block bell housing bolt pattern... on a second note, welcome abord
Old 02-12-2006, 07:45 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
They're right. 2.8 is a 60 degree engine, the 4.3 is a 90 degree.
Old 02-15-2006, 07:18 PM
Question Re: transmission swap
Bummer that won't work. I have several chev 350's from '78 chevy 3/4 tons.
would they work?, I know v8's are put in s-10's but a believe they are small blocks.
What do I have Small or big blocks. I know engine mounts have to be changed and other things , but is it feasible? As you can tell i'm a novice but not afraid to educate myself and give it a go.
Old 02-16-2006, 02:20 AM
with that 2.8, you need a fuel pump, and the delivery system for the type of system you go with (ie 78 is carberated, and the 90's is fuel injected) lots to do, will be expencive, if you want some details, ill list all i can think of, just let me knwo what your wanten to do
Old 02-17-2006, 03:37 PM
sounds like it is going to be out of my price range and way above my ability.
going to ponder situation. However, I am very happy with the 4.3 engine
(after all is it not a chev 327 with two cylinders removed?) need to find a manual transmission that will fit behind it to really enjoy it. A half-ton tranny work?
thanks for all the help!
Old 02-18-2006, 03:32 AM
its a 350 -2, 4.3/6=.7166 L/cyl... .7166x8= 5.7L... 61.4 ci= 1l, 5.7x61.4= 350... yes, it is an extreamly expencive project, with my 4.3 in the truck the swap is costing me close to 3k finished, and any manual tranny from a full size or s 10 should fit behind it
