Old 02-11-2006, 11:10 AM
macdad614 macdad614 is offline
Question 2003 LeSabre rear disc brake pad replacement
Does anyone have info on instructions for replacing the rear pads? Any links to view photos or diagrams on this procedure?
The Haynes book covers thru 2002, so I did not know if it covers 2003 model.
Chilton DVD for this year won't be out until May. Their print versions don't cover 2000+.
Buick service manual(s) cost $135.
My front pads wore down and ground into rotors without any warning until grinding started. 36,000 miles. Repair shop replaced rotors also. I don't want to have to pay that price again.
Old 02-11-2006, 01:33 PM
maxwedge maxwedge is online now
A990 racer
Re: 2003 LeSabre rear disc brake pad replacement
2002-2003 procedure is the same.
Old 02-11-2006, 05:25 PM
xtreme barton xtreme barton is offline
jack hole ass end up..
use one of the sides as a guide
Old 02-11-2006, 11:59 PM
Thumbs up Re: 2003 LeSabre rear disc brake pad replacement
Thanks - I appreciate the reply.
In the well-worn Haynes manual, it was suggested that the caliper did not have to be removed entirely to replace the pads. Any suggestions (other than jack up the [w]hole rear end)? It was more or less obvious what had to be removed to replace the pads on the '78 Vette.
Old 02-12-2006, 10:01 AM
A990 racer
You can pivot the caliper on one stationary slider pin, you will see this when you get in there.
Old 02-12-2006, 10:21 AM
yeah its pretty easy to understand how it works when you get into the job
