Old 02-11-2006, 12:12 AM
dissturbbed dissturbbed is offline
3000 gt sl transmission problem?
i just bought a 3000 gt sl and it is awesome, the only problem i have is when it up shifts from second to third the engine sorta revs up a little before shifting..,sometimes it does this and sometimes it don't and its only from second to third, am i going to have to get ready for a transmission over haul or is it just something simple?
Old 02-12-2006, 02:07 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 3000 gt sl transmission problem?
manual or automatic? what year model? please provide more information to help diagnose the problem.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-12-2006, 08:46 AM
1999 3000 gt sl automatic....
Old 02-14-2006, 12:28 AM
Linebckr49's Avatar
ok. so sometimes on the 2-3 shift the engine revs a bit before going into 3rd????
a bit confused. so when the engine revs a bit more, are you still applying the gas? does it ever feel like it won't shift into 3rd? send a PM to HotShot8972; he is very experienced with the automatic transmissions.
93 3000GT base
Old 02-14-2006, 10:20 AM
yes that is correct it revs right when it is shifting from 2nd to 3rd...this is with normal excelleration,...ill try HotShot8972 and see what he has to say
