| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Compression low?
120 110 110 110
thats my compression, its pretty even but I thought it was supposed to be at like 170-180?
95 Eclipse GS-T 6 bolt built block - shooting for 450 hp..very doable Currently: A lot, check progression thread - updated 3/27/10 Estimated completion date: Soon lol |
Re: Compression low?
Yes that is low. Do a wet test and see if the compression raises. Dump a cap full of oil down each cylinder and recheck your compression.
2g compression: 178psi is standard 133psi is the service limit |
If it goes up it means you're rings are worn if it stays the same (or really close) it's either valve seats, head gasket, or warped head.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
Well I did a wet compression test too and the results were:
120 115 110 110
Well it just might be time for a rebuild.
![]() But either way it looks like your pulling a head to see whats wrong.
Got AWD? Some people buy super cars, other build them ![]() ----Click It, For Mods and Pics---- '95 Mitsubishi Eclipse GSX - For Sale '05 Volkwagen Golf GLS TDI - My daily driver '03 Ford Excursion 6.0L PSD 4x4 '13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost '08 Buell 1125R '83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap |
Yeah, you're gonna need to do something soon, does the car still run?
It will run once I replace the crank position sensor.
The compression in my talon was about that bad and it wouldn't run for shit. I think mine ranged from 95 to 140 though, and such a huge variance is worse than all of them being low.
Wet tests are not effective on flat-top pistons. They are good to do on dome style pistons only. On flat-top pistons the oil just puddles giving a false higer reading becasue of the extra volume.
DSM geek |
yep if those readings are accurat, it's rebuild time
now - 2000 civic soon - 2002 is300
Well, I have a lot on my plate right now, including an 8 hour drive to FL in the middle of march, would I be better off buying a new engine and just dropping it in and rebuilding a monster out of my old one, or just rebuild it?
Or can i just take a built bottem end and a head from SBR and use my cams to build everything?
it all depends on what your goals are for the car. if you want a monster, you'll need to build it up but you'll need more than just a built bottom end and a sbr head, you'll need gauges and loggers and what not. the quickest way to get it running is to get a different motor (used or new) and just swap them out. the cheapest route will be to re-build it yourself if you know how but it will take more time than just a complete swap. your car, your decision.
Well, im thinking about ordering the stage 1 long block for now, then having my motor on the side slowly building it. Do I absolutely need the 2g conversion for it, its another 1400$
