Old 02-10-2006, 07:08 PM
pmacjack pmacjack is offline
front hub assembly
I am having a front end problem which from all of the threads I have read it sounds like my front hub assembly on my 2000 ZR2. My question is how can I tell which assembly needs to be changed? In my situation the noise stops or gets quieter when I turn left and gets worse if I turn right. From what I have read it sounds like this is the passenger side assembly but I could swear the noise is coming from the drivers side. Is this a common misconception. Thanks.
Old 02-10-2006, 07:21 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: front hub assembly
Those symptoms would indicate that the driver's side is bad.
Old 02-11-2006, 12:23 AM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
Jack both of the front wheels off the ground and slowly spin each tire. A bad hub you can hear and feel without a problem.
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 02-11-2006, 02:57 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
when you turn right, which way do you go? towards the drivers side, which means the suspension is loaded on that side, and the passengers side is unloaded, load the bearing and thats when it gets worse (usually)
Old 02-11-2006, 07:15 PM
billibong's Avatar
billibong billibong is offline
I have the same symptoms on my '99 Blazer. When I jacked it up - like BlazinMlew stated - I was able to tell it was the drivers side. It only takes a few minutes, and you'll know where the problem is.
You will probably find out that it is your drivers side hub assembly.
Good luck, and let us know how it turns out.
bill
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
