| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
steering problem
I could turn the steering wheel 1 and 1/4 rotation to the right but i could only turn 1 full rotation to the left and that is barely getting to 1 full turn. Everytime I back up and turn the wheel all the way to the left, it locks up, i cant turn it to the right unless I get in gear and move forward a little. Then it kinda pops out. This is after I got into a car accident. the lower control arm was replaced and so was the tie rod end. both on driver side. My theory is that the tie rod end is hitting the suspension arm? then if im driving and wanted to do a hard right turn, if i turn the wheel more than 1 full rotation, it will turn the last 1/4 but itself. hmm weird...
1997 Mitsubishi Eclipse GS-T 5spd stock ?Tsudo 3" catback Bomz Intake HKS SSQV BOV bcs mod and a useless boost gauge |
Re: steering problem
Please use of the adequately tagged "problem diagnosis" sub-forum.
I removed the steering rack and it looked fine. I used a vise grip and turn the pinion/gear on the steering and it moved fine. Full left and right turn. I thought maybe it's just the tie rod end hitting the knuckle thats causing the problems so I put my rack back, adjusted the rod. It still locks up on reverse left turn. Any ideas? Maybe the rack IS busted?
