Old 02-10-2006, 06:14 PM
jashar jashar is offline
Door Panels
How do I remove these? And put them back on? I need to install some new speakers..
1997 ford escort lx sedan
Old 02-15-2006, 08:06 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: Door Panels
If the 97 is anything like my 94, the panels simply pop off... they are pressed in with clips and all you should have to do is wedge something in near each one and pry it loose.
Old 02-17-2006, 12:54 AM
Davescort97 Davescort97 is offline
Escort guy
Re: Door Panels
You'll need to take the window handle loose if you don't have power windows. Push the panel in behind the crank handle and you will see a clip on the shaft inside. Take a coat hanger and bend the end of it to snag the clip and pull it off. To put it back on you just put it on the handle and push the handle back onto the shaft.
