Go Back   Automotive Forums Car Chat > Saturn > General Discussion
Old 02-10-2006, 04:56 PM
lansdowne lansdowne is offline
not blowing hot enough air
Hello: 2002 Saturn doesn't seem to be blowing very hot air...could that be a thermostat problem or what else might possibly be the problem??
many thanks, lanssdowne
Old 02-16-2006, 11:53 AM
pontiacman428 pontiacman428 is offline
Re: not blowing hot enough air
It could be an air pocket keeping the coolant from the heater core.
I would make sure it's full run it with the coolant cap off for maybe 20min. but keep an eye on it so if it starts to cough the coolant out you can keep it in check.
If it's a thermostat not opening enough, then it would probably run a little on the hot side or it could be a weak water pump.
Old 04-22-2006, 09:19 PM
boarder_punk's Avatar
boarder_punk boarder_punk is offline
Send a message via MSN to boarder_punk
The heater core could also have internal corrosion preventing sufficient coolant flow.
