Old 02-10-2006, 04:31 PM
panzer dragoon panzer dragoon is offline
Tech2 C-code list
Description
Module
DTC C0035 LF Wheel Speed Circuit Malfunction
ABS
DTC C0036 LF Wheel Speed Circuit Range/Performance
ABS
DTC C0040 RF Wheel Speed Circuit Malfunction
ABS
DTC C0041 RF Wheel Speed Circuit Range/Performance
ABS
DTC C0045 LR Wheel Speed Circuit Malfunction
ABS
DTC C0046 LR Wheel Speed Circuit Range/Performance
ABS
DTC C0050 RR Wheel Speed Circuit Malfunction
ABS
DTC C0051 RR Wheel Speed Circuit Range/Performance
ABS
DTC C0060 LF ABS Solenoid #1 Circuit Malfunction
ABS
DTC C0065 LF ABS Solenoid #2 Circuit Malfunction
ABS
DTC C0070 RF ABS Solenoid #1 Circuit Malfunction
ABS
DTC C0075 RF ABS Solenoid #2 Circuit Malfunction
ABS
DTC C0080 LR ABS Solenoid #1 Circuit Malfunction
ABS
DTC C0085 LR ABS Solenoid #2 Circuit Malfunction
ABS
DTC C0090 RR ABS Solenoid #1 Circuit Malfunction
ABS
DTC C0095 RR ABS Solenoid #2 Circuit Malfunction
ABS
DTC C0110 Pump Motor Circuit Malfunction
ABS
DTC C0121 Valve Relay Circuit Malfunction
ABS
DTC C0131 ABS/TCS System Pressure Circuit Malfunction
ABS
DTC C0132 ABS/TCS System Pressure Circuit Range/Performance
ABS
DTC C0141 Left TCS Solenoid #1 Circuit Malfunction
ABS
DTC C0146 Left TCS Solenoid #2 Circuit Malfunction
ABS
DTC C0151 Right TCS Solenoid #1 CKT Malfunction
ABS
DTC C0156 Right TCS Solenoid #2 CKT Malfunction
ABS
DTC C0161 ABS/TCS Brake Switch Circuit Malfunction
ABS
DTC C0186 Lateral Accelerometer Circuit Malfunction
ABS
DTC C0187 Lateral Accelerometer Circuit Range/Performance
ABS
DTC C0196 Yaw Rate Circuit Malfunction
ABS
DTC C0197 Yaw Rate Circuit Range/Performance
ABS
DTC C0236 TCS RPM Signal Circuit Malfunction
ABS
DTC C0240 PCM Traction Control Not Allowed
ABS
DTC C0241 PCM Indicated Requested Torque Malf
ABS
DTC C0244 PWM Delivered Torque Malfunction
ABS
DTC C0245 Wheel Speed Sensor Frequency Error
ABS
DTC C0252 Active Brake Control Sensors Uncorrelated
ABS
DTC C0253 Centering Fault
ABS
DTC C0550 ECU Malfunction
ABS
DTC C0710 Steering Position Signal Malfunction
ABS
DTC C0870 Device Voltage Reference Output # 1 Circuit Malfunction
ABS
DTC C0875 Device Voltage Reference Input # 2 Circuit Malfunction
ABS
DTC C0896 Device Voltage Range/Performance
ABS
DTC U1XXX Lost Communication with XXX in Data Link Communications
ABS
DTC U1300 Class 2 Data Link Low in Data Link Communications
ABS
DTC U1301 Class 2 Data Link High in Data Link Communications
ABS
DTC U1650 Chassis System Dedicated Bus Controller Malfunction
ABS
DTC U1651 Chassis System Dedicated Bus Sensor #1 Malfunction
