Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 02-10-2006, 03:15 PM
greenone08 greenone08 is offline
Question Need Amp Help
I recently bought 2 12" sony Xplods and a box with a 1200 watt amp and i installed it and everything except now i keep having problems with it it turns on when i turn my car on and i turn up my radio but whenever it gets to loud it turns off and wont turn back on for a couple of days.... I NEED SOME HELP plz help me asap
Old 02-10-2006, 03:26 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
Re: Need Amp Help
well where did you wire the trigger wire(remote) from the amp too? if its do an acc wire then thats why it kicks on when you turn the key on. if its wired to a remote output on an aftermarket head unit, then it only kicks on when the radio is on. and the reason for the amp shutting down is it probably has some kind of internal cut off. im not sure exactly on anything since i dont know exactly how everything was wired.
Old 02-10-2006, 03:33 PM
Re: Need Amp Help
I ahve it wired to an aftermarket radio its wired to the remote wire on it and it comes on with the car its just it worked fine for a week now it keeps cutting me off when i barely turn it up
Old 02-10-2006, 03:35 PM
Re: Need Amp Help
bad connection, bad wire, bad ground, bad amp. ill see what this guy i know has to stay, if i can get ahold of him. he knows car audio like no other. what kind of amp is it, so he will know.
Old 02-10-2006, 03:37 PM
Re: Need Amp Help
It is a Sony Xplod 1200 Watt amp ill try and replace the ground and stuff ill keep checking this site THANX a lot for the help
Old 02-10-2006, 10:14 PM
Re: Need Amp Help
ok from the guys, they say the gain is set too high. the amp volume. the amp is shutting down because its set too high. you need to drop the settings down on it. make sure its on low pass filter, running very low frequency (so it doesnt distort), and dont use bass boost if it has it. but they said turn the gain down on the amp, because thats most likely the issue. other then that, its going to be a bad amp. they told me ever since sony made the xplod series, its been junk.
Old 02-11-2006, 12:33 PM
Re: Need Amp Help
thanx for the help im gonna try it out ill get back to u if it doesnt work thanx ALOT
Old 02-17-2006, 09:15 PM
lonelywolf8588's Avatar
lonelywolf8588 lonelywolf8588 is offline
Re: Need Amp Help
Check the ground connection. If you screwed it into the sheet metal make sure that all the paint is cleared away from the ground point to get a good connection. You may also want to get a capacitor if you don't have one. It will save your battery and alternator and it won't cause you interior lights to dim on hard hits.
Old 02-21-2006, 01:56 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: Need Amp Help
I totally agree here, even with the sony junk. Your gain is way high most likely. you should list the current settings you have your amp at as well as the type of head you have. if you ask me, sony car electronics are the worst you can put in a car (worse than wal-mart even). I've seen too many instances of sony subs and amps blowing in a month or two after purchase to consider them good products. Decks don't read CD's too well either.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
