Go Back   Automotive Forums .com Car Chat > Buick > Roadmaster
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 02-10-2006, 02:39 PM   #1
Kgilljr
Unhappy Roadmaster remote program
How do I program my new remote to open the doors on my 1996 Roadmaster wagon?
Kgilljr is offline
Old 02-10-2006, 08:54 PM   #2
ilgoldstein
ilgoldstein's Avatar
Re: Roadmaster remote program
Try this procedure, which is posted in this forum.
http://www.automotiveforums.com/vbul...63&postcount=5
ilgoldstein is offline
Old 02-11-2006, 04:46 AM   #3
Kgilljr
Thanks, I viewed this procedure and looked in the rear of my wagon, but, even after taking out the side panel I couldn't find the plug and wire described. I'll try taking out more stuff.
Kgilljr is offline
Old 02-11-2006, 08:15 PM   #4
ilgoldstein
I poked around and found this link that might be helpful in locating the plug:
http://impalassforum.com/cgi-bin/ult...;f=20;t=002605
Good Luck!
Old 02-12-2006, 06:04 AM   #5
Kgilljr
Thanks, I'll take a look. Ken
Kgilljr is offline
Old 03-07-2006, 03:04 PM   #6
Kgilljr
Smile Re: Roadmaster remote program
Thanks for all the help! I got it done.
Kgilljr is offline
Old 03-07-2006, 08:02 PM   #7
Onblsht
Authorized Vendor
Onblsht's Avatar
If you push aside the molding on the rear driver side pillar post (just behind the rear window) you will find a small black circuit for initializing the keyless remotes. Take some copper speaker wire & bridge the two metallic nodes (completing the circuit). When this is done, you will notice the door locks will begin cycling automatically - click one button on each remote sequentially and the system, in turn, will store the code for each remote. Remove the wire & put the molding back in place - you're done.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Onblsht is offline
Old 07-08-2006, 12:09 PM   #8
SharkHead
SharkHead's Avatar
One of my remotes quit working-put in new batteries-no luck-any typical problems to look for? Could one of the remotes have become "unprogrammed"?
Also, is there any way to add a "horn beep" or any other features to the programming?
TIA,
Ben III
SharkHead is offline
Old 07-14-2006, 03:30 PM   #9
Kgilljr
My problem was that I only had one remote and I wanted to program another. In doing that I did program both of them. Try reprogramming both. As far as the beep, if the manual does not refer to that you probably can't. But, someone may have a way to do that. Good luck, Ken
Kgilljr is offline
Old 02-06-2007, 12:09 PM   #10
christogq
I have a 94 Roadmaster sedan and I can't find the "Plug" in my trunk. Can somebody post a picture of what I'm supposed to be looking for?
christogq is offline
Old 02-07-2007, 04:46 AM   #11
Kgilljr
I have a Wagon, but, the "plug" is actually a receptacle. It's black plastic with two wires and there are two slots for a connecting plug. And, there's no "plug" to go into it. On the sedan, it should be behind the panel on the drivers side of the trunk. It's about 3/8 inch square and 1 1/2 inches long. Try some of the links in the other replies, especially the Impala Club link. Don't give up, Ken
Kgilljr is offline
Old 02-07-2007, 08:47 AM   #12
christogq
Thanks man. I'm gonna try to find a picture cause I think my plug might be missing. Like there's a wire that was cut or something. I hope it's not for the release.
Old 02-07-2007, 09:49 AM   #13
HotZ28
AF Moderator Elite
HotZ28's Avatar
Wink Re: Roadmaster remote program
Welcome to AF!
If you like, you may start a New Thread on this subject. This thread is over one year old, so therefore, it will be closed. Click Here and read.
Thanks for your cooperation.
HotZ28 is offline
Closed Thread
