Old 02-10-2006, 02:33 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
bicep
need tips to get out of my plateau with curls. I can do 50 lbs alternating dumbell curls, 80 lbs on a barbell, and a sad 60 lbs on the preacher (this is all reps of 6-10 and sets of 3). I've been stuck at this for a few months now.
Also, what different muscles are worked between a hammer curl and a regular curl? I can do more weight on the hammer curls.
btw, i work my triceps as much as my biceps and the still put on mass and i have not plateaued on them yet.
thanks
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 02-11-2006, 12:18 PM
sivic02's Avatar
sivic02 sivic02 is offline
Re: bicep
Try doing things like close grip and wide grip barbell curls, chin-ups, and overhand curls. Take a barbell, grip it overhand, keep your elbows behind you, and do curls...cry after each set. Good luck man.
Hammer curls work the biceps brachialis which is the lower bicep muscle while a regular curl works the biceps brachii which is the top biceps muscle. (Im pretty sure I got that right)
Here's to being single, seeing double, and sleeping triple
Old 02-12-2006, 01:47 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: bicep
one thing you can do is work the negative motion of the curl, so you work on the way down. this helps build muscle and strenth more than a normal curl. what you do is you get a weight that's heavier than what you can do on curl, then youbring it up, you place you arms on a swiss ball, you will probably need to lean back to get the weight up, then you allow your arms to go down, but you do so very slowly.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 02-13-2006, 01:03 AM
Re: bicep
^don't understand what u are talking about
Clear Corners
Iridium Spark Plugs
Old 02-13-2006, 09:09 AM
nissan_240sx nissan_240sx is offline
Re: bicep
Heres a site all about building biceps, good luck
http://www.ebicep.com/
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 02-13-2006, 02:57 PM
Re: bicep
im just saying that it'll give you a better work out if you work on the way down of the curl rather than the way up. just start from the top with a heavy weight and fight it all the way down, repeat.
Old 02-14-2006, 12:12 AM
Re: bicep
^got it, thanks
Clear Corners
Iridium Spark Plugs
