Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-10-2006, 02:09 PM
cody_stl cody_stl is offline
Send a message via ICQ to cody_stl Send a message via Yahoo to cody_stl
Break Down...HELP
Ok my friends car is a 90 Teg gs i believe...the engine if i am not mistaken is a b18a1. It has 170,000 on it and the other day when he first started it up and came to work he said it was almost like it was missing and running on three cylinders.Then when he went to lunch he heard a kinda SNAP sound and it died. New battery.Wont start.When you crank the engine manually it gets hard to rotate at a certain point,and the starter can barely turn it over.I dont know if these engines are known to go out...if its an internal component snap,or maybe a bad starter.Any help would be appreciated.
Thanks
Old 02-10-2006, 09:40 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Break Down...HELP
power? fuel? spark? timing?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 02-10-2006, 10:06 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
easy now, dont confuse him...
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 02-10-2006, 11:35 PM
TurboGSR96's Avatar
TurboGSR96 TurboGSR96 is offline
Send a message via AIM to TurboGSR96
"he heard a kinda SNAP sound and it died. New battery.Wont start.When you crank the engine manually it gets hard to rotate at a certain point,and the starter can barely turn it over."
Sounds to me like the engine seized.......Did you two happen to check the oil? If you guys know what oil looks like inspect the oil on the dipstick and see if you see any metal shavings.
R.I.P 00' ITR #479
1996 GSR: Built Bottom - Built Head - Big Injectors - Big Turbo - Computer Thingy - 500+ whp
*2-6-06* Waiting for the Full-Race Stg 3 with GT35R
.82 a/r Upgrade and Nitrous Express NXL
http://www.cardomain.com/ride/2241056
Old 02-11-2006, 01:30 PM
eclipser2001 eclipser2001 is offline
how often was the oil changed? did he run his car hard alot? im no mechanic, but sounds like the cylinders are seiged, like what turbogsr96 said.
Old 02-11-2006, 02:13 PM
AF - Advisor
it cranks hard with the spark plugs still in?..................try pulling the spark plugs out then do it again.
so when you start the engine with key on the "ON" position, it cranks...................? slow? fast?
slow = check power. you said new battery, well, how are the connections?
fast = time to check fuel, spark, and timing.
Old 02-11-2006, 04:07 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
a snap?? i would check everything like these people said... it should still run with a spun bearing or snapped rod it would just make ALOT of noise... if it gets hard to turn with a wrench then the motors done
Old 02-12-2006, 12:06 AM
shadow2154 shadow2154 is offline
Exclamation Re: Break Down...HELP
I work for a Acura Dealership.
Remove the Valve cover and then try and crank the engine. If nothing is moving up top then the Timing Belt is snapped. If it is...then I sudgest that you remove the Top end off and see if the pistons are turning. But first make you that your getting fuel, air, spark. A good way of checking for spark is to put a screwdriver into one of the wires, hold it close to metal and see if it arcs when someone turns the key.
Old 02-13-2006, 02:13 PM
Ummmmm...he says he thinks he found out what it is.He said two things(rocker arms or lobe or sumpthin)underneath the valve cover on the valve train have snapped.Can remember exactly what it is he said.At first he thought it jumped timing,now he found this.The first thing we thought was the engine seized, but i dont think this engine is known for seizing at only 170k. Yes the oil has been changed MORE than regularly seeing how he is managment at Valvoline and i work under him. Kinda disappointing that he may be able to fix it.lol.He said if it was a crank or rods or the pistons he wouldnt mess with it and was gonna give it away....ME ME ME...i need an engine for my 4g Civic Hatch.
Thanks for the suggestions guys
Old 02-13-2006, 03:40 PM
TurboGSR96's Avatar
Shadow, I wouldnt recommend you telling them to stick a screwdriver into anything involving an electrical spark (you do it for a living....not them).
I would say the best thing is to take it to a Mechanic (not a hillybillie!) and let them check it out. It is gonna have to get there anyways it sounds like so I wouldnt mess with it too much yourselves.
R.I.P 00' ITR #479
