Old 02-10-2006, 01:21 PM
davidzog davidzog is offline
"91 S-10 Failed Emissions - HIGH HC - help???
My son's 91 2.8L s-10 failed with high Hydrocarbons but had low CO....
The catalytic converter was rusted and noisy, so we had it replaced and I replaced the IAC valve as the idle was goofy, and I also am going to replace the oxygen sensor and EGR valve this weekend.
However, the engine idle recently started surging from 800 to about 1200 rpms (back and forth) and I have no idea where to look...any help on passing emissions and idle surging would sure help a lot...thanks
Old 02-10-2006, 07:18 PM
maxwedge maxwedge is offline
A990 racer
Re: "91 S-10 Failed Emissions - HIGH HC - help???
High hc's are usually raw fuel fumes, make sure the oil is freshh, the vapor cannister is not loaded, no misfires. As for the rpm surge, vacuum leaks # one, carb base, possible egr not seating was common, scan it and look for codes and proper sensor operation also.
