Old 02-10-2006, 11:11 AM
travis2822 travis2822 is offline
Send a message via Yahoo to travis2822
Coolent Leaking Not Sure Where
I have a 99 S-10 4x4. I am beginning to loose coolent. I am not sure exactly where it is leaking from. It looks like the vecinity of the water pump. I noticed a little bit of rustiness on top of the pump. My engine is clean so it looks like water had to be there. I haven't known them to leak on top only through the hole on the bottom. Any ideas if it could be something else? It is not leaking a lot. I have to top it off every 2 or 3 days.
Old 02-10-2006, 12:05 PM
Southern Comfort's Avatar
Southern Comfort Southern Comfort is offline
Re: Coolent Leaking Not Sure Where
It could be your radiator cap. they are known for being bad.
Old 02-10-2006, 12:18 PM
biv343 biv343 is offline
Could be the infamous intake gasket as well.
Old 02-10-2006, 02:48 PM
muddog321 muddog321 is offline
AF -Advisor
If the water pump look at the bottom hole from underneath while its running. If the intake check the front between the block and intake right above the water pump and also it may leak into the "V" between the valve cover and intake so use a light and look there too. If its the V and you park on a grade it runs down front or rear (front down hill then runs down the front). Also, there is the famous leaking heater core but you will smell that one in the cab. Any hose could also spring a leak but so far never had one leak in my 4 blazers 98 up.
Old 02-10-2006, 06:29 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Go to AutoZone and rent or borrow the pressure tester. Pump it up to the pressure rating of the cap. You shoulld be able to find the leak real quick.
Old 02-11-2006, 01:05 AM
GirlBear's Avatar
GirlBear GirlBear is offline
I agree. Also if ur pump was leakin u would prolly have heard it b4 u saw it.
http://jowulf.deviantart.com/
Old 02-11-2006, 02:07 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
its either the water pump, doubtful, never seen one leak from the top, could be a hose, could be the intake, if its the intake feel lucky, i checked the oil in my show truck today, and it was chocolate milk colored, my moter is now a boat anchor, when it goes outside like yours did if its bad, nothing bad happens, gaskets need changed, the bad news is if you dont want to do major engin work, its going to cost you between 650 and 1200 usd
Old 02-13-2006, 08:44 AM
It "only" cost me $387 to get my intake gaskets changed at the dealer. Couldn't believe it. Dealer was cheaper than the independent shops.
Old 02-13-2006, 09:37 AM
joeuser742 joeuser742 is offline
I also had a coolant leak when I 1st got my 98 Blazer 4x4 (around 100k miles). Mine was leaking from the hose (top one, I think) and the waterpump. It probably would have been fine if I would have just changed the waterpump gasket, but while it was apart, I just changed the pump. Easy job.
Old 02-13-2006, 10:59 AM
scholzee scholzee is offline
My 1996 has the "weep hole" on top of the water pump it was leaking out of there and then running down the sides.
Old 02-13-2006, 12:51 PM
a new water pump is cheep enough to just change it, not worth doin just the gasket
Old 02-13-2006, 05:56 PM
I changed the radiator cap a few months ago when I read the post about it. If the intake were leaking wouldn't there be water in the oil? It is supposed to warm up in the next couple of day and I'll take a look at the hoses and look a the water pump real good and we'll see.
Old 02-14-2006, 12:07 AM
depends, the jacket can split two different ways, one is yes into the oil, that happend to me, but, by pure luck i watched it happen, checked my oil, changed it, ran it for filter fillup and then a final check and the intake had popped, couldn't be any luckyer... the other way is the jacket can pop to the outside and seep out quite good from the base of the intake and the heads
