Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 02-10-2006, 11:09 AM
alphalanos alphalanos is offline
Rear sway bar size, 96 Civic
I'm looking for a rear sway for my 96 Civic. I'll be using a subframe brace and aluminum LCAs. Is a 19mm like Suspension Techniques good enough, or should I go with something bigger?
96 EJ6. Future home of boosted B18C1.
Old 02-12-2006, 01:50 PM
BullShifter's Avatar
Re: Rear sway bar size, 96 Civic
19mm is a good size.
Old 02-13-2006, 12:39 PM
LVApex's Avatar
LVApex LVApex is offline
Hard to say, how is the car handling now? understeer? oversteer?
any way for a street driven car, a 19mm would probably be perfect.. it should reduce alot of understeer, and not cause engough oversteer to get you in to trouble.
Old 02-13-2006, 01:58 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
19mm will be fine. You probably wouldn't notice too much differance to a 22mm bar such as the ITR one. I used to run a 22mm ITR bar till it ripped out my subframe. Then I downgraded to a 15mm Del Sol VTEC rear swaybar, and maybe it's just my suspension setup, but there was no real differance in car handling other than it wouldn't oversteer as easily when I'd try. The car still has the same amount of roll between the 2 bars though.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 02-22-2006, 05:22 PM
NOBU-SAN NOBU-SAN is offline
Who makes a 15mm rear sway other than Honda? I checked on the prices(@ a local Honda Parts Dept), and they are outrageous. I can't seem to find anything at a local yard either. Silver, does your bad experience have anything to do with the idea of auto-x, or any type of sanctioned racing in which you drive like a madman out of necessity? Just curious, I wonder if I'd be okay with a bigger than 15mm bar considering I don't race. I just want it to do some serious scooting around town. Thanks, sorry for the thread jack, I have concluded that I need a bar/set of bars. I need too much loot to do the JRSC right now, and I'm getting a little bored.
1998 Civic EX 2dr MT :Koni RSK suspension, ST 19mm Rear Sway Bar, Hawk brake pads, Civic Hybrid wheels(No bullshit), C- West style front bumper, Apexi N1 cat back, AEM cold air, LSR short shifter... more to come!!! Holler back.
2006 SV650: M4 carbon high mount, racetech springs & oil up front, seat cowl, suzuki frame sliders, new shock coming soon......
Old 02-22-2006, 05:25 PM
I'm using an A Spec Racing subframe brace with mine. It prevents tearout, Im also using Omni Power lower control arms, Energy suspension bushings, and some '99 Si end links. (I have a '96 LX)
Old 02-22-2006, 08:56 PM
Cali Guy
Good combo there!! I run the Omin arms too and I like them A LOT better than the cheap POS Megan arms I used to have. I wish braces like the A-Spec one were made back when I had my bar on...
Anyways, Nobu-San, I emailed you back on your questions so check it when you can.
hessemer69 on AIM
