Old 02-10-2006, 10:04 AM
batmobile78m batmobile78m is offline
Partial Loss of Power
'97 2.2
Plugs and wires are new.
It never had good pick-up to start with, but now it takes forever to get from 25mph to 50mph, even if floored. This condition seemed to happen rather suddenly a couple days ago.
Everything seems fine except for this lack of quickness to 50mph. Once there it runs fine.
Any guesses?? thanks
Old 02-10-2006, 12:42 PM
|WYG|SS |WYG|SS is offline
Re: Partial Loss of Power
Originally Posted by batmobile78m
'97 2.2
check the throtle positioning sensor.
Old 02-10-2006, 12:48 PM
zirb zirb is offline
Change your fuel filter. Then run a can of seafoam in the fuel tank.
Old 02-10-2006, 02:42 PM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
heres a good question did it get worse after you changed the plugs. and wires. Could be either a bad wire or a mis positioned wire
Old 02-10-2006, 08:46 PM
muff34 muff34 is offline
'97 2.2
Have you had it checked for codes? If no codes ,I`d change the fuel and air filters. I have a 2000 with the 2.2 and it`s not that peppy either ,I just figured it was a gutless wonder being a 4 banger. Maybe I`m missing out on some hidden power ......LOL ,but I love the 36 to40 MPG Muff
Life Is A Highway ,Enjoy The Ride
Old 02-11-2006, 04:04 PM
It has run well for a couple months since i changed plugs and wires.
No codes logged.
TPS is OK.
Fuel & air filters have been replaced recently.
Never heard of this seafoam stuff. Have to check it out.
Still struggling to find something. thanks
Old 02-11-2006, 08:33 PM
JeRkY2 JeRkY2 is offline
What kinda mileage do you have on the car?
I've never heard of seafoam before but you could try running a few tanks of gas with some injector cleaner in it. If you have a sticky or partially plugged injector, this may help. If it is an injector you may want to take it to a garage to have them clean the injectors this they would use a more concentrated formula. The stuff you put in your tank once in a while is usually best for preventative maintenance.
If it has a lot of mileage it could be possible that you have a plugged catalytic conveter or a worn out camshaft.
Old 02-12-2006, 07:54 PM
182,000 mi
I thought about the injector cleaner. I'll try the pour-in type, but that hasn't worked too well when they were dirty before. A cleaning fee of about $120 at a shop around here. Was trying to avoid that.
clogged converter, could be. camshaft, maybe. Do you know of any way to check those things?
------Feels like trying to accelerate with the brake partially on-------
I've narrowed it down to about a dozen different things. Might take a while.
Old 02-12-2006, 08:24 PM
check oxygen sensor casue i lost some power with mine when it was bad and once i replace it it ran good. not sure if it can be the problem. all i know is it can give the computer a bad reading and then different amouts of gas. has the gas been staying about the same level for a long amount of time?
Old 02-13-2006, 11:50 AM
Banned
lol i got around 185,000 on my 2.2. I had to change the coil packs this week end they were giving me a bit of trouble. how old are your 02 sensors?
