Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-10-2006, 08:49 AM
BiggWaukegan BiggWaukegan is offline
Didnt Pass Emissions
Someone please help me out. Took my caprice for annual emissions and it Barely failed. To much unburned gas{hydrocarbons}is what the dude told me. Was thinking of replacing the O2 sensor and the air filter then retrying? Any suggestions? O yes, I did get the springs and shocks done all the way around and its sittin SWEET. I mean real SWEET. thanks chicago springs! please help me out why my car is not passing emissions.
Old 02-10-2006, 09:48 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Didnt Pass Emissions
Any more specifics on your car, such as model year, engine etc?
My guess is that replacing the air filter is a good thing, but I'd verify there wasn't some other problem before replacing the EGO sensor. Was the car fully warmed up to operating temperature when you had it tested? Is it running on all 8 cylinders? Spark plugs or wires can contribute to this, as can a maladjusted carb (if your car is carb'ed). An engine that is not fully warmed up may not be properly burning all the fuel, leading to the HC failure. A vacuum leak can also cause HC failure by leaning out the mixture. In that case, failure occurs because there is insufficient fuel to provide a smooth burn, leading to an amount of unburned fuel going into the exhaust. A failed smog pump (AIR system) can cause HC failure by providing insufficient oxygen for the catalytic converter to do its job.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-10-2006, 10:41 AM
its a 91 with a 5.0 V8 moter. i believe all the wires and plugs are good. air filter is good. could it be the oxygen sensor? i no that controls the mixture of gas,.
Old 02-10-2006, 01:57 PM
Cyrix_2k's Avatar
Cyrix_2k Cyrix_2k is offline
if you could *ahem* create and exhuast leak at the exhuast side of the muffler, say by loosening a clamp, it should help some. That's how my neigbor got their van to pass... lol.
1996 BMW 318i Convertible
1989 Caprice Brougham - 305 V8, TH-2004r - FOR SOLD!!!
Old 02-13-2006, 11:31 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Did you get a readout of what failed exactly? Then we'd be better prepared to help with figures to go by.
Old 02-13-2006, 12:07 PM
CAPRICE LIFE CAPRICE LIFE is offline
Send a message via AIM to CAPRICE LIFE
Lean Out Ur Carb...itll Help Alot
IF IT AINT BROKE,DONT FIX IT
IF IT IS ASK ME
Old 02-13-2006, 02:11 PM
silicon212's Avatar
Confoundingly Lucid
No it won't. #1, the idle mix screws cease becoming a factor when the throttle plates open up, even slightly. #2, you run the risk of overheating if it is too lean at idle. #3, leaning out the idle too much WILL cause it to fail both HC and NOx at idle. Nonetheless, the car in question has TBI and not a carb, so there is no idle mix screw.
If you want to cheat it through emissions, you can retard the ignition timing a little (2-4 degrees) and adjust the idle speed higher (1200 in park).
Old 02-13-2006, 04:06 PM
Got the Diag. test ran and my mechanic dude said its a bad catayaltic convertor and i need a full tune up. was thinkin of doin plugs, wires, cap n rotor, O2 sensor, pcv valve, air filter, and of coarse the convertor. My mechanic dude said he will do it all for 350 does that sound fair? Should i put the money in it? can i still cheat it through even though the Cat. convertor is shot? Also the car seems to be eatin up alot of gas recently as well. Could this be because of the Cat. Convertor? If i invest and do the things listed above including the convertor do u think i will see a noticable difference in gas mileage? thanks
Old 02-18-2006, 12:12 AM
tribal terror tribal terror is offline
O2 can be watched on the scan tool or pull it out and see if it's coated white as this also creates a rich condition. Also check the injectors on top of the throttle body to see if they are spraying or dripping the fuel(dripping is not good).Tune up and O2 will help the emissions if they are needed,$350 is an excellent price if being done correctly and all that work is included.
Old 02-22-2006, 06:26 PM
cavie 00 cavie 00 is offline
Thumbs up Re: Didnt Pass Emissions
i have a 96 caprice 9c1 had the same problem. got a good tune up done on it, plugs, plug wires, O2 sensors, throttle body cleaned, check all the idlers to keep it steady, last thing i did was to change the cat cost me alot of money on those cuz its a pain in the ass to find sum for a 4.3.
good luck!
