Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-10-2006, 07:53 AM
nova1313's Avatar
nova1313 nova1313 is offline
Cat converter and o2 sensor
http://cgi.ebay.com/ebaymotors/OBX-C...37106708QQrdZ1
Is whats in the above link really a high flow cat? I found alot that appeared to be just test pipes marked as high flow cat's. I was also wondering with this can I still use the o2 sensor so that I may pass emissions. It looks like it should work (see the bolt on the one end.. i'm assuming the sensor goes there..
If anyone has one and could let me know that would be great thanks!
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 02-10-2006, 08:00 AM
DragonofBC DragonofBC is offline
Send a message via AIM to DragonofBC
Re: Cat converter and o2 sensor
I doubt that it's real. For $25 more, you can get the magnaflow cat that I got (check out the thread "Opinions on exhaust setup" for a link) which is EPA and CARB certified. And it has 3" in/out rather than 2.5". Just a thought...
2003 Mustang GT Convertible - 5sp. - K&N drop in, MAC catback, Eibach Pro Kit springs, Strange s/s, GMS UCAs/LCAs, MGW shifter, Nitto 275s out back. Does it ever end...
Old 02-10-2006, 08:09 AM
nova1313's Avatar
I see. Does that allow you to use the o2 sensor then? I need that for emissions I don't want to have to change out my cat every time emissions rolls around.
As per shpyder's post in your thread I'm looking to do his dual dual tip exhaust setup (the mufflers are sitting in my room actually just need to pick piping) and I can't really go larger then 2.5" for that. I guess I could go 3" up until the cat and then after when I do the y drop it to 2.5"
Old 02-10-2006, 08:23 AM
I don't know about the O2 sensor question. I certainly hope so because I'm going for an emissions legal car as well. I didn't realize there was an O2 sensor back there.
Old 02-10-2006, 08:26 AM
Sorry for the double post.
Now you've got me worried. I just found this cat on ebay where you can get the O2 bung as well.
http://cgi.ebay.com/ebaymotors/3-Mag...spagenameZWD1V
Old 02-10-2006, 08:38 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
it looks just like a test pipe to me. e-mail the company and ask them to take a picture of the inside of it.
95 Talon TSI AWD
97 Eclipse GST
Old 02-12-2006, 06:04 AM
Nayr747's Avatar
Nayr747 Nayr747 is offline
From what I have read it is just a resonator. I don't know how they have gotten away with saying it's a cat for this long. There are 2 o2 sensors--one in the o2 housing and one after the cat (its job being to report if the cat is functioning). With a hig-flow cat such as the Magnaflow or a Catco (both around $60 w/out flanges welded on), they should not report a CEL. W/out a cat you will need to take out the 2nd o2 sensor and wrap it in tin foil or some other method to avoid a CEL.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 02-12-2006, 10:44 AM
SLoe's Avatar
SLoe SLoe is offline
Resonators all! Don't be a cheap bastard. Get the name brand.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 02-12-2006, 12:24 PM
nova1313's Avatar
i wasn't trying to be cheap. I just don't know what is good in this application. I've searched but no one gave a definitive answer like these are good and you can pass emissions with them.
If I had that id drop the money. but the magnaflow is the first i heard of hey this is good and you can pass emissions but now im not sure about the o2 sensor question.
Does anyone have a high flow cat, with an o2 sensor properly installed that doesn't throw a cell or would fail emissions? if so what brand and where did you get it from?
Old 02-12-2006, 01:37 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
As far as i know there shouldn't be a cat that eliminates the O2 the O2 sensor is behind the cat correct?
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 02-12-2006, 01:59 PM
xtreme barton xtreme barton is offline
i wouldnt get that one from ebay. take the advice from the others and get a quality one from a quality place.
im sure if it didnt have a place for O2 than it could be made
Old 02-12-2006, 02:16 PM
I changed my order to the Magnaflow 94039. It has a bung already in it to put the rear O2 sensor. Stock, the O2 sensor is in the pipe after the cat but since I'm changing the pipes, I needed somewhere else to put the O2 sensor. You can just leave it connected and wire tie it up under your car. The rear O2 doesn't do anything except check to see you have a working cat. When your cat goes bad, it emits a gas that fouls the sensor, causing it to fail. Thats when you get a CEL and what would cause you to fail emissions. If you take it out of the system but leave it connected (or do the mod on VFAQ) you won't get a CEL.
A CEL will cause you to fail emissions on a 95+ eclipse from what I gather (depending on what state you are in and what kind of tests they run). I'm not worried about passing emissions with my soon-to-be setup.
Old 02-12-2006, 04:22 PM
nova1313's Avatar
here we have visual (I assume that a missing o2 sensor would make it fault not sure htough), gas cap check, and also a check of the computer for 96+ obdII vehicles.
Old 02-12-2006, 05:05 PM
95 eclipses are OBDII compliant. I haven't gotten it done yet but from what I've hear, MA sounds about the same.
Old 02-12-2006, 10:44 PM
nova1313's Avatar
im not sure what they would od there though because our law i believe calls out 96 + get that and below that you get a different set of tests. as of 96 manufacturers were obdII required I think.
