Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 02-10-2006, 01:10 AM
Reflect Reflect is offline
Convert Auto to Man 96 xr7????
I am woundering about converting my trans to a manual I have been told that the cougar has a similar mountings and would be the easiest to covert with is the 96 mustang. My cougar is the 4.6L V8.
Old 02-10-2006, 01:05 PM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Re: Convert Auto to Man 96 xr7????
Yes, you can use a manual transmission out of a '96 Mustang (T45).
You will need an shifter extension box.
The driveshaft will need to be shortened, or a custom shaft made up, using the T45 type Yoke.
Your EEC will need to be re-programmed.
I'm sure there is more to the conversion.
Old 02-17-2006, 11:02 AM
C. Cleve C. Cleve is offline
Hi, RE your conversion to manual trans,Consider the fact that you will have to POSSIBLY reprogram the processor, or most likely replace it with the proper one for the manual shift conversion, The processor presently in the vehicle is programed for auto trans application in ALL aspects, Examples are to name just a few.....ignition timing and advance curve, air fuel ratio, I wish you luck, just trying to help.....GOOD LUCK,....Clay..
