Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-09-2006, 10:05 PM
KHarney KHarney is offline
Exclamation 95 Talon Timing Issue!!! Need Help!!!
95 Eagle Talon ESI 2.0 DOHC (all factory parts) 133,000 miles
Was recently running but real sluggish until it reached 3000 rpms. Then today, it started, drove about 50 feet and stalled. Will not restart. Cranks and cranks. Plugs are firing, compression is 120. Timing belt is real tight when not running, but flaps wildly when running. Will replacing the timing belt, tensioners, etc help? Thanks
Old 02-10-2006, 08:11 AM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: 95 Talon Timing Issue!!! Need Help!!!
What do you mean it flaps wildly when running? That doesn't sound good at all.
1969 Olds Cutlass
1985 Olds Cutlass
2000 Ford Ranger
2001 Jeep Cherokee Sport
Old 02-10-2006, 08:34 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
when was the last time the timing belt was changed? it sounds like the tensioners not even working correctly and your timing is way off if it runs so shitty. i wouldn't drive/start it until you get the problem fixed, you run the rist of bending valves.
95 Talon TSI AWD
97 Eclipse GST
Old 02-10-2006, 09:12 PM
I just bought this car 2 days ago and the previous owner said the timing belt was never changed! Definately sounds like my problem is the timing belt. I guess my main worries are if the valves and heads are okay. A mechanic will be taking it apart tommorrow so time will tell. Thanks for the help.
Old 02-11-2006, 10:55 AM
Don't forget the pistons. Valves hitting the pistons works both ways.
1969 Olds Cutlass
1985 Olds Cutlass
2000 Ford Ranger
Old 02-13-2006, 09:18 AM
Turns out the timing belt tensioner was destroyed. Bearings fell out when the timing belt came off. Everything was replaced, but now there is a ticking (maybe clapping) noise coming from the timing belt area. Mechanic says it is because everything is new and tight right now? Gets better at higher rpms but it is pretty loud. Is he right or just covering up something he doesn't feel like dealing with?
Old 02-13-2006, 09:55 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Sounds exactly like what happened to mine. Original belt @103k. 1 month after I bought it the belt slipped. Time for a 1g head swap!
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
