Old 02-09-2006, 10:44 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Lighting Help
I can not figure this one out. The rear running lights on my t/a work perfectly when ever they should be on. There are brand new bulbs in every light socket. Now whenever I hit the brakes all the lights on the rear right side go out except for one, its just that side thought. Any thoughts, I was thinking maybe a short but wouldn't be side be going out? Also the brake fuse is fine.
White 07 STI, Bone stock for now
Old 02-10-2006, 03:21 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Lighting Help
Do the blinkers to that side sometimes not blink as well? and the dash blinker lights but does not flash?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-10-2006, 09:28 PM
ViperJ's Avatar
Re: Lighting Help
I am not sure about the rear blinker lights, I know the ones in the dash work. I will check out the rears...
Old 02-10-2006, 09:38 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Lighting Help
Mine has a brake light issue sometimes but it happens more commonly cause of the turn signals and since they share the same lights. I am curious to see if it happens with them as well.
Old 02-10-2006, 09:39 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Lighting Help
Oh and most likely its being caused by light corrosion in the socket from built up moisture being trapped in the housing.
Old 02-11-2006, 05:55 PM
ViperJ's Avatar
Re: Lighting Help
Yes the turn lights do work with the brake lights lights "on"
Old 02-13-2006, 10:36 AM
ViperJ's Avatar
Re: Lighting Help
So should I try cleaning out the socket part or can I buy new sockets and just wire them in
Old 02-13-2006, 12:56 PM
79Bandit's Avatar
79Bandit 79Bandit is offline
Re: Lighting Help
i've got somewhat of the same problem my rear lights work untill i hit the brakes the right side dims also my right side blinker doesnt work. im thinking its a short....somewhere ( all new bulbs. )
Old 02-13-2006, 01:00 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Lighting Help
I every so often clean out the socket with wd40 but the problem with mine and may be the problem with yours is that there is moisture getting into the enclosure. So whenever my car is washed or parked outside in the rain more water gets in there . You may want to see if there is moisture in there and then look at the seal all the way around the tail light and see if you can see where its getting in. I plan on putting in the new style Honeycomb tail lights so I have made piece with this temp problem.
Old 02-14-2006, 08:44 PM
ViperJ's Avatar
Re: Lighting Help
Yes there is moisture in the taillights, maybe that it.... I am only trying to get this fixed because the cops around here are very picky
