Old 02-09-2006, 09:35 PM
bad3kgt's Avatar
bad3kgt bad3kgt is offline
Send a message via AIM to bad3kgt
Do you know what would cause this?
Ok, say im driving doing about 40mph and i come to a stop, i down shift to second and then just drop in neutral and when i do that the rpms drop below 1 and the lights dim like its gonna cut out. The car idles just fine but im just wondering why its doing that and if its a problem.
==--92 Mitsubishi 3000gt SL--==
Mods So Far
JSpec Engine
3sx Stage I Clutch
3sx Downpipe
Unorthodox Underdrive Crank Pulley
Bomex Bodykit
18x8 Chrome rims
Old 02-09-2006, 10:16 PM
Igovert500's Avatar
blue + red light magnet
Re: Do you know what would cause this?
Might be your alternator going.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-09-2006, 10:26 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
battery also, thats what was going on when my battery started going out
Old 02-09-2006, 10:36 PM
Igovert500's Avatar
Autozone tests both for free.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-10-2006, 07:43 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
As everyone else has said, alternator or battery. However, your car is supposed to idle at about 750 rpm, it should not idle above 1000rpm.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 02-10-2006, 08:31 AM
bad3kgt's Avatar
I think your right, my alternator might be going now that i think about it.......great
Thanks guys
Mods So Far
JSpec Engine
3sx Stage I Clutch
3sx Downpipe
Bomex Bodykit
18x8 Chrome rims
Old 02-11-2006, 01:23 AM
Morphius289's Avatar
Morphius289 Morphius289 is offline
It's definitely the alternator. Those are the exact same symptoms that my car had while the alternator was dying. Just don't drive your car too much. If you do, you might drain the battery, hence your car won't start.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 02-11-2006, 01:43 PM
JaceWade JaceWade is offline
My TT idles around 1200 or a little higher. If i leave it sit it jumps a bit between about 1500 and a little below 1000. What would be the problem here? if any?
'93 Blue Stealth R/T TT
Borla Cat Back
K&N Cold Air Intake
'92 Blue Stealth R/T w/ rebuilt auto. tranny being parted out! PM me for all offers, it must go!
Old 02-11-2006, 06:20 PM
StealthModifier StealthModifier is offline
my voltage regulator went out in my altenator. driving it down the road it was past the max voltage. at a stop light it would be at 11. it was bad enough that it blew out my headlights. luckily i had just pulled in my driveway that night they blew out. its most likely ur altenator.
Old 02-12-2006, 02:24 PM
Igovert500's Avatar
Faulty IAC. Irregular idle is caused by vaccuum leaks, spark plugs, and bad o2 sensors. Time to pressure test for boost/vaccuum leaks!
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
