Go Back   Automotive Forums Car Chat > Ford > Contour
Old 02-09-2006, 06:07 PM
mtkayser mtkayser is offline
98 contour radio,remote mirrors,map lights not working
i have a 98 contour which the radio and the map lights and the remote mirrors are not working. i checked the fuse box under the dash and the fuses are good. what would cause all these to go out at the same time. thank you i need fast help
Old 02-09-2006, 10:13 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: 98 contour radio,remote mirrors,map lights not working
same damn thing in my car, i had to run a new hot wire for my radio cause I couldn't figure it out, pissin me off!
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 02-09-2006, 10:36 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Found this on contour.org with someone that had the same problem.
Found the problem, the main dome light was the culprit!! Damn blue bulb melted a portion of the plastic causing two of the metal contacts to...uh...well, contact.
Btw, all of these are fed by fuse 34, so I would double check that fuse seeing as its the most likely culprit.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 02-09-2006, 11:29 PM
pre98zetec's Avatar
thanks, I replaced my whole 'dome' unit out of a 95 SE when I got my instrument cluster.. though.. But I will go and double check fuse number 34 tomarrow. is the clock ran off this also? because mine is non-functional.
btw how the hell did you find that lol? I searched two days and didn't find anything except 'check your fuses'
-Josh-
Old 02-10-2006, 03:06 AM
pre98zetec's Avatar
well i just checked the dome light and it was fine, i didn't check the fuse yet though.
-Josh-
Old 02-10-2006, 07:33 AM
It only took me a couple minutes. I guess Im the CEG search guru. But yes, the clock is connected with F34.
"The CEG Nazi"
www.contour.org
Old 02-10-2006, 05:30 PM
thanks everyone that did the trick. fuse #34 protects interior lighting and digital clock but is also the link between the radio and mirrors and map lights
