Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-09-2006, 05:10 PM
50-shot 50-shot is offline
Banned
Nitrous question plz help
would a 50 shot of dry nitrous destroy my Integra gsr with 130000 miles on it? i have only exhaust headers and intake. would it give me 50 Horse power. and how easy is it to run the line from my trunk?
Old 02-09-2006, 05:52 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
Re: Nitrous question plz help
depending on the shape of the motor you might need to rebuild the internals...nitrous will put extra stress on your motor similar to that of forced induction...if your motor is in good condition just dont spray the hell out of it and you should be ok...in time it will wear out the motor though
Old 02-09-2006, 05:56 PM
Banned
do i have to put a purging valve on it? my motor is in real good condition i burn alot of oil tho is that normal for a vtec. is zex the way to go?
Old 02-09-2006, 06:10 PM
ZEX is a good nitrous kit and many ppl with hondas run the 55-shot...as for burning oil vtec does burn oil but it shouldnt be anything overexcessive so you might have a problem there...and do you mean the purge cloud valve? if thats what your talking about than no its not needed
Old 02-09-2006, 06:29 PM
Banned
i burn 3 quarts about every 2 months. idk all i know is its just called a purge valve
Old 02-09-2006, 06:42 PM
pepsihatman's Avatar
pepsihatman pepsihatman is offline
Send a message via AIM to pepsihatman
How much oil you burn will also depend on how hard you drive your car. I used to wail on my car, redline it every day, and I burned about a quart of oil every oil change. I've calmed down quite a bit and typically keep the revs under 3k, while redlining the car maybe once a week, and I have burned less than an 1/8th of a quart at every oil change.
3 quarts sounds like a lot of oil to be burning (just from my experiences). Do you notice any blue-tinted smoke coming out the exhaust?
~!~David~!~
1998 GSR, 86k miles, AEM CAI, DC 4-2-1 Ceramic Header.
Old 02-09-2006, 07:13 PM
Banned
no smoke and i beat on my car just like you said redline constantly. i dont no why its a habbit i been pretty good tho latly i dont beat on it
Old 02-09-2006, 07:20 PM
WReX WReX is offline
well i wouldn't be introducing nitrous to a motor that burns 3 quarts every two months
i would fix the problem of the oil consumption and not beat on the car nearly as much unless its not your daily driver
26 PSI anyone?
Old 02-10-2006, 02:45 PM
Banned
thx for the information fellas im going ahead and gonna put her in when i get 400 dollers
Old 02-10-2006, 03:11 PM
He wasn't telling you how to drive. He was telling you how to keep your engine from blowing up if you put nitrous on it. Remember you are the one who asked us for advice.
~!~David~!~
Old 02-11-2006, 05:52 AM
integrawhat integrawhat is offline
Send a message via AIM to integrawhat
comming from someone who has blown a motor with the zex kit i will say that it is a very safe kit if you are careful, dont leave it armed if you arent using it, and dont abuse it (it will be more addictive than crack when you first install it) the 55 shot should be fine just bump back the timing a little and definatly check into that oil burning problem BEFORE you run hard on the bottle or you'll be shopin for a new motor...
ps. i deffinately do not condone the use of crack!!
A.K.A. GOT WIDE
darton 84mm MID's ls stroke 2.0l GS-R
pnp head with full skunk2 pro series valve train
and pro1 cams
custom divided top mount w/garrett gt4094r
not stoping till i hit 750hp to the wheels
this aint your mom's car so DONT F***ING TOUCH IT
