Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 02-09-2006, 04:33 PM
TheDeal526 TheDeal526 is offline
No Air Filter
1989 Thunderbird Standard 3.8 V6
OK, in one of the more bone headed things i've done so far, I drove my 1989 Thunderbird for a little over an hour and a little over 15 miles without an air filter. Its a K&N, and I took it out when I parked my car last night because Ive been meaning to service it for some time now. I never got around to cleaning it, and I completely forgot I had even removed it. Now for those 15 miles, could I have done any damage to my engine at all???
THANKS ALL.....
Old 02-09-2006, 04:50 PM
xtreme barton xtreme barton is offline
Re: No Air Filter
i dont think damage .. but you probably got alot of dirt into the engine ..
what i would do is:
1. spray down your throttle body with cleaner
2. change the oil
Old 02-09-2006, 05:07 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
Re: No Air Filter
unless you drove off road ofr in a very dirty area you are fine
Old 02-09-2006, 05:33 PM
Re: No Air Filter
i was thinking about cleaning the throttle body. after spraying throttle body cleaning into the throttle body, will the plugs become dirty and require changing?
Old 02-09-2006, 05:36 PM
Re: No Air Filter
nah .. if you would like you can take them out and clean them and re-gap them if it makes you feel better
Old 02-10-2006, 10:10 AM
overl0rd overl0rd is offline
Re: No Air Filter
Get a can of sea foam and spray it into the throttle body.
Old 02-10-2006, 10:21 AM
Re: No Air Filter
i wouldnt bother with sea foam.
like mentioned above he didnt drive very long.
he most likely can just not do anything and be fine. but if it worries him then just spray some el'cheapo cleaner in the TB and change oil ..
Old 02-11-2006, 12:40 AM
Re: No Air Filter
Yeah, but he would probably still benefit from a good cleaning.
Old 02-11-2006, 04:47 PM
Re: No Air Filter
spray cleaner is cheaper and can give good results. benefits on an average car needing cleaning is pretty much the same.
