Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 02-09-2006, 05:14 PM
jgraap0625 jgraap0625 is offline
possible pcm problems???
i have a 95 dodge neon and im having problems with it, when you start it up the battery light comes on right away, and then when it warms up it also starts to run bad, it runs good at an idle but any more then that it spits and sputters, i have given it a charging system test and everything is charging fine but the light is still on. i store my car in the winter and just before i did this year i had degreased the engine, and the night that i did that everything froze, can somebody give me a clue as to what happened?
Old 02-09-2006, 05:47 PM
xtreme barton xtreme barton is offline
Re: possible pcm problems???
so your alternator and battery have been tested ?
do you have any vacuum leaks ? and do you have a timing light ?
you may want to check into a map sensor to
Old 02-12-2006, 03:59 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Is your check engine light lit? If so, do the key dance to pull the codes. Spitting and sputtering sounds like the spark plugs need to be changed to me, but that would be a guess w/o more info being given.
