Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 02-09-2006, 03:53 PM
HPNOTIQracing HPNOTIQracing is offline
damn f*ckin thing
im trying to get the fuckin timing sprocket off the end of the crank. i put a puller on it and it broke the little lip that it lips under. so ive heard to hit it with a chisel and hammer and it breaks pretty easy, no luck
Old 02-10-2006, 07:39 PM
maykelcj's Avatar
maykelcj maykelcj is offline
Re: damn f*ckin thing
use the puller from autozone. Use the une that uses bolts to bolt on the treads on the sproket. I had to go and buy some long bolts from lowes.
12:1 all motor neon, sold
got me a CRX HF and put a DOHC ZC on it.
Old 02-10-2006, 11:56 PM
sbiddle sbiddle is offline
I just change the T-belt on my Neon and had a heck of a time getting the pulley off. Use the largest 3-jaw puller that will still fit. It has to grip the outside of the inner part of the pulley. Use the right side engine mount bolt in place of the crank bolt since it's longer. Good luck!
Old 02-12-2006, 02:46 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Here is a great post that should help you out...
http://forums.neons.org/viewtopic.php?t=237728
