vibration
when i hit or exceed 80mph the car vibrates. i can hear the rythem of this vibration at lower speeds but at 80mph i can feel it and it sucks. i tried balencing the front tires. hub bearings seem to be ok. any ideas?
Re: vibration
I had the same problems with my car and it was driving me nuts. It turned out that I did have a bad tire after I had them ballanced 4 times. These tires were brand new as well so it pissed me off. Other then your tires I don't know what it could be.
MODS: 2001 Mitsubishi Eclipse GT Spyder,17" Konig Wheels, AEM Underdrive pully and Air Intake System, B & M Short Shifter with MOMO boot & shift knob, High Performance Drilled & Slotted Roters w/Hawk Brake Pads, Centerforce Stage 2 Clutch, Fidanza 9lb Flywheel and a Magnaflow Full Catback Exhaust System. |
Re: vibration
![]() same here, uneven wear associated with a lack of rotating the tires regularly, i don't think people realize how much that matters to the life of your tires, the sumitomo's i had lasted... 10k miles or so that way, not that they were supposed to last much longer anyways but you get the idea flat spots also cause this problem bottom line, new tires (get some good ones, it makes a big difference) , alignment, balance, and plan on rotating them in 7500 miles if that doesn't work, get new rims, they aren't terribly strong so bending them will cause some vibration, stock ones aren't hard to find and i'm looking at purchasing an extra set soon GTS style
![]() Don't act like you don't love it.
503/2000 |
Re: vibration
as Elchico said....new tires.
Re: vibration
I agree with that. Had the same problem with my GT. Especially if your car is lowered and you don't have an aftermarket chamber kit on the car. It seems like it eats the inside of your rear tires. But anyways new tires fixed that with out a problem
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads. |
Re: vibration
until i get new tires, should i consider it out of the question to go beyond 100mph. i mean am i going to loose control or loose a wheel or anything by going fast
Re: vibration
I would not go any faster than what feels safe. If it starts to feel bad after like 80, then dont do more than 80. I doubt you would lose control or a wheel or anything, but its just not a smart idea. Stupid way to crash your car (and doing 100 might kill you if you crash)
2000 Fed. Spec GT-"Lafawnduh" Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp |
Re: vibration
control is based entierly on the driver as for loseing the wheel its posable.
Id just get new tires ASAP just buy cheep 1s that are new and have the wheels balenced/ alignment and all that good stuff. if it still shakes after that the frame might be tweaked or even simpler a strut is blown. |
Re: vibration
sumitomo's are on tirerack for cheap...
they wont' last very long (10-15k miles) but you can save for some better ones in the mean time oh yeah... WHY THE HECK DO YOU NEED TO GO OVER 100?!!?!?one?!question!?!?!?!
503/2000 |
Re: vibration
I agree with everyone else. If you are going over 100 and you have a blow out your doomed. Not a very safe thing to do.
Where do you live where you have 100 mph speed limits anyway. I want to move there. As far as getting cheap tires, I don't think that is very smart. Your wasting your money if they will only last 10 to 15 K miles. You could invest that money in a good mutual fund or something. Buy the best, it will save you money in the long run.
Re: vibration
if i own a vehicle that can go that fast, i will drive it that fast and the reason why is a 45min drive on I88 almost every day.
my last car was a 95 grand am gt and it had absolutely no problem ever going 115 the whole way. i see the eclipse (in perfect working order obviously) a more fit vehicle to do such in buddy of mine that works at discount tire says that yokohamas are reasonably cheap and will last a pretty good while... should i go for it or something else... |
Re: vibration
I have heard nothing but good things about yokos. Go for it if you can get em cheap.
Re: vibration
i have yoko's and have never had problems with them yet, neither have my friends that use them for drifting.
