Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-09-2006, 11:47 AM
abebesheir abebesheir is offline
Replacing rear-end w/ one w/ a diff. ratio
I have to replace the rear-end in my 1992 9c1... The local junkyard has a few Caprice wagons. They told me that the rear-end from the wagon would work just fine in the 9c1 sedan.
The gear ratio on my car is 3:42, the ratio on the wagon is 2:73, what differences in performance should I expect with the change in gears?
Old 02-09-2006, 12:17 PM
DenisM DenisM is offline
Re: Replacing rear-end w/ one w/ a diff. ratio
the car will be noticeably slower off the line, but will have some increase in top speed and fuel efficiency.
Old 02-09-2006, 01:45 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
you would get much better gas mileage, but you car would be slugish off the line
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 02-09-2006, 03:36 PM
All that is wrong with the rear end are the inner and outer pinion bearings and crush sleeve.
Since the price of a wagon rear-end was only $150... I was tempted to go with it. However, since it would noticeably affect the speed off the line, I have put that idea to sleep.
The price of a used 3:42 posi rear-end would be $400 plus installation.
I was told not to just replace the inner and outer pinion bearings as this would cause grinding.
Is there some way I can get out of this mess for less than $300?
