Old 02-09-2006, 11:32 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Found out the no start problem
I broke my balance shaft belt, which in turn, jumped my timing a few teeth and messed up a sensor underneath. Only another 4 or 5 hours of work to go
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 02-09-2006, 11:42 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Found out the no start problem
You probably bent some valves man, major work required. 99% sure if you skipped timing you bent some vavles
now - 2000 civic
soon - 2002 is300
Old 02-09-2006, 03:48 PM
ned032002's Avatar
ned032002 ned032002 is offline
I wouldn't doubt it that you bent some valves either. GL
Old 02-09-2006, 04:30 PM
Well, since then, I found out I was wrong, the timing looked off, but when we went to line it up, it wasnt.
Car wont start because the crank position sensor shattered basically.
Also we did a compression test:
120 110 110 110
Arent I supposed to be around 170-180? 95k miles on the engine
95 Eclipse GS-T
Currently:
Soon lol
