Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-09-2006, 06:34 AM
metolious69 metolious69 is offline
Should I flush transmission or just replace fluid/filter?
I've a 2000 4WD Tahoe with a little over 100,000 miles. I haven't done any transmission work since I bought it at 70,000 miles. And I'm unsure of what transmission maintenance the previous owner did.
I'm having no transmission trouble but thought it may be time to flush or just drain and replace the fluid/filter. I've heard mixed reviews on doing both. I'm looking for recommendations. I don't want to flush the system and then start having tran problems that I didn't have before. Not sure if the old saying fits "if it ain't broke, don't fix it".
Any help/advice appreciated.
Old 02-09-2006, 09:58 AM
wafrederick wafrederick is offline
Banned
Re: Should I flush transmission or just replace fluid/filter?
Do not flush,replace the fluid and filter.My father knows a guy that has his own transmission shop that does valve body cleanings because someone had their transmission flushed.The lines are above the filter and where does the dirt go during a flush?,in the valve body and the valves stick.I had to replace one transmission because it was flushed and acted right up after the flush.
Old 02-09-2006, 10:21 AM
gkindub gkindub is offline
metolious69, check the color of your tranny fluid against new. If it's not bright red in color you need to change fluid and filter asap. Consider using synthetic if you plan to keep the vehicle awhile. While you're at it you might want check your owners manual for 100k service intervals for Fr & Rr Diff's and transfer case.
Regards, gb
