Was wondering if anyone has had a problem with the rear window washer? Mine doesn't seem to work at all, though the wiper works fine. I know the 1988s had a separate tank, but from the owner's manual and Haynes, looks like both the front and rear run off the same tank. Is there a separate pump? The front window washers work fine. Don't have to use it much here in AZ, but do like it to work when I need it. Thanks.
Re: 97 T&C Rear Window Washer
You could also try going under the hood in the power dist center just above the battery and pull the IOD fuse for a couple minutes , this will sometimes fix stuff like this if the pump is still good , its all controlled by the bcm .
Thanks for the replies. Went out today to see what would happen, doggone thing worked fine. Would have been nice if it had last fall driving through some rain in CA. May have just dried up in the line here in the AZ heat and temporarily blocked it.
