Go Back   Automotive Forums Car Chat > Honda > Odyssey
Old 02-08-2006, 10:58 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
04 Odyssey replacing cabin filter
Has anyone done this? I just bought the filter and the instructions with it say that there is a brace that is to be cut and discarded... sounds a little fishy to me. any input appreciated!
TIA
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 02-09-2006, 08:02 PM
lorunner lorunner is offline
Re: 04 Odyssey replacing cabin filter
Yep. Remove the glove box and you will see a pice that spans the opening thats the same color as the dash. At both ends you need to cut only the plastic out. Leave the metal brace behind it. You will see what looks to be dotted lines where you need to cut.
once the plastic is out of the way rmove the 2 8mm screws that hold the brace in and you can then get the filter out.
Stop asking me about radio codes I cant get them anymore!!!
Old 02-24-2006, 05:51 PM
OldFaithful OldFaithful is offline
Yep. The part you cut is there to space things during assembly and is no longer needed. Just follow the instructions as I did for my 04.
Jim
