Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 02-08-2006, 09:29 PM
CONWAY TRUCKER CONWAY TRUCKER is offline
Exclamation 2003 Expedition Door Locks
Just Bought A 2003 Expedition Eb ,having Problems With Rear Doors Not Locking With Remote Or Door Switch. I Have To Lock And Unlock By Hand . Thanks For Anyones Help. Also Does The Auto Trac Come On All E.b .s As Standard Equipment?
Old 02-17-2006, 05:49 PM
luweee luweee is offline
Re: 2003 Expedition Door Locks
are the rear locks on the same fuse, or power line?
sounds to me like a power issue.
no power to the locks.
is the fuse blown?
Old 02-21-2006, 05:55 PM
akiestler akiestler is offline
Do You Know Where The Door Lock Relays Are Located
Old 03-06-2006, 01:39 PM
cdc692003 cdc692003 is offline
Thumbs up Re: 2003 Expedition Door Locks
sounds like the actuators inside the doors themself....very costly if that is the problem.....labor mostly.......all door locks work on same power line....
hope this helps.....
Old 04-03-2006, 10:35 AM
RumblinTLR RumblinTLR is offline
I'm having the same problem with my 01 Expedition. I called the dealer and they want between $300-$500 to fix. I'm going to try and replace the actuators myself. Doing the research now
Old 04-04-2006, 03:37 AM
KimMG KimMG is offline
AF - Advisor
Check the wiring in the doors to make sure the actuators are being energized.
Make sure the electrical connections are clean and secure.
Make sure the linkage is clean and lubricated and can move easily.
