Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 02-08-2006, 09:19 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
lifter tick
What causes lifter tick? How would I be able to fix it? I have this ticking sound coming from the driver side. It sounds like its coming from the 4 and 6 cylinder, around that area. It only ticks after a long drive. When I start the car in the morning at 5 am (its around 50 degrees) I doesnt tick. Some that why Im confused.
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 02-08-2006, 09:36 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: lifter tick
check the oil level. if that is fine, change your oil. dirty oil can cause your lifters to stick.
ZedEx Crew Member #2
Old 02-08-2006, 09:48 PM
Re: lifter tick
what oil filters are good? i heard that fram is garbage. What oils are good? Right now I am running Castrol syntec. I had Royal purple before castrol.
1997 Eclipse GS-T
Old 02-08-2006, 10:23 PM
Re: lifter tick
i personally am using a wix filter with mobil 1 synthetic oil.
Old 02-09-2006, 04:56 PM
probehtr300 probehtr300 is offline
Re: lifter tick
yeah Wix is great, but fram does make a new "tough guard" filter with a anti- flowback valve that keeps some oil in the heads for startups and is actually a decent filter for a DD.
Past Z Car Crew
-josh
Old 02-09-2006, 07:03 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
Re: lifter tick
I use the K&N oil filters myself, with mobil 1 synthetic... as previously stated, lifter tick usually just means you need an oil change... if not one of em' could be collapsed
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 02-09-2006, 07:31 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: lifter tick
i always used a Fram but that will probably change when i get it running again.
i have heard good things about Mobile 1 Synthetic oil so i will probably be using that but i havent looked into oil filters much.
ZedEx Crew Member #4
