Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 02-08-2006, 09:51 PM
greenz71 greenz71 is offline
slack in shift lever
i have a 94 b2300 5 speed that has slack in the shift lever side to side and up and down i've pulled the gear shifter out and cant figure out what it could be i dont think it anything major because once i find my gear it drives just fine
2000 z71 escb k&n fipk tb spacer hyper tech programmer flowmaster exhaust flex-a-lite fans 3in body lift cranked torsion bars with ford keys super lift aal rancho 9000x shocks with in cab adjustment
315-75/16procomp mt
82 cj7 4in super lift springs with spring over up front 6in super lift spring in the back 36x12.50-15 super swamper tsl
94 mazda b2300 stock as you can get (gas saver)
if it wont go i dont need it
Old 05-15-2006, 03:49 PM
GrimShadow GrimShadow is offline
Re: slack in shift lever
It sounds like your bearings are worn out in the trany.
My stick was loose, rite before the trans stoped working. @ 90,000 miles
I had to rebuild mine myself. I got the rebuild kit from Auto Zone. They are the only people that carry the rebuild kitt. It only contains the bearings, but thats all that was worn out on mine. Get this fixed before it becomes a bigger problem. If te bearings get to bad, you will destroy the sincros*.
Hope this helps.
